not understanding where to attach physical wires
- johns00056
10 Mar 2014 01:55 - 10 Mar 2014 01:58 #44608
by johns00056
not understanding where to attach physical wires was created by johns00056
I got a sample configuration to load in my computer. I have been through all the manuals, at least 100 times, and I am just not getting the part about hooking up wires to the 7i85 daughter board.
I have 5i25, 7i85 and 8i20 brushless servo drive powered up with the LEDs lit up as they should be.
I am confused by the dmesg. It lists pin numbers followed by numbers in parentheses . These numbers sort of look like they match up with the picture on page 6 of the 7i85 manual, except the labels are different.
The labels list something about muxed encoders, but the 7185 manual shows 3 encoder connectors and 5 serial communication connectors.
Looking at servogreen.hal I see only one place to connect a wire-GPIO 25 for the home switch.
on jog.hal I don't see any places to attach wires.
Last edit: 10 Mar 2014 01:58 by johns00056.
- johns00056
10 Mar 2014 01:59 - 10 Mar 2014 02:04 #44609
by johns00056
Replied by johns00056 on topic not understanding where to attach physical wires
I have been told that the setup wizard will not work for my cards.
Last edit: 10 Mar 2014 02:04 by johns00056.
- Thank you received: 5192
10 Mar 2014 02:44 - 10 Mar 2014 02:59 #44610
Replied by PCW on topic not understanding where to attach physical wires
One thing at a time...
A good first step might be to connect encoder 0
According to the manual (pages 3 and 6) this connects to 7I85 pins 1 through 8 on TB3:
TB3 PIN FUNCTION DIR
1 QA0 TO 7I85
2 /QA0 TO 7I85
3 GND FROM 7I85
4 QB0 TO 7I85
5 /QB0 TO 7I85
6 +5V FROM 7I85
7 IDX0 TO 7I85
8 /IDX0 TO 7I85
Last edit: 10 Mar 2014 02:59 by PCW.
- johns00056
10 Mar 2014 02:59 #44611
by johns00056
Thank you for your response. The encoder hookups make perfect sense to me , so I will go ahead and do that.
- johns00056
13 Mar 2014 20:24 #44759
by johns00056
I got the encoder connected and it seems to work. The display counts up and down when I turn the motor by hand.
When I enable the 8i20 brushless servo drive the motor starts to turn slowly and continuously with low power. I can stop it with my fingers. (I have the drive belt off.)
I don't know how to home it.
13 Mar 2014 21:58 #44761
Looks like the sample config is set up for magnetic (Thump) BLDC commutation init
(thats the "q" option) so it may in fact have initialized the motor commutation
If it continues to turn, thats a good thing (that means commutation is working)
But this is somewhat unlikely as these BLDC parameters would have to match your motor/encoder
from the sample file:
setp bldc.0.initvalue .3
setp bldc.0.scale -4000
setp bldc.0.poles 4
This is setup for a 1000 line (4000 count) encoder and a 4 pole motor
(it would also work to a 8 pole motor with a 2000 line encoder)
Do you know the encoder counts and number of motor poles?
Note that the motor current is quite limited until the NVMaxCurrent is set to the 8I20s
maximum (30A) but this is probably a good thin at this point
setp bldc.0.poles 4
- johns00056
14 Mar 2014 00:15 #44764
by johns00056
It has a 2048 encoder and the motor is 8 poles.
14 Mar 2014 00:37 #44766
OK so that means that you need:
setp bldc.0.scale -8192
setp bldc.0.poles 8
If you have not already done so
note that the scale may need to be reversed (to 8192) depending on you final axis
directions, and encoder connections
setp bldc.0.poles 8
- johns00056
14 Mar 2014 00:55 #44768
by johns00056
I did that, no change yet.
14 Mar 2014 01:10 #44769
does the motor run continuously when enabled?
Time to create page: 0.216 seconds
