Homing a dual-motor-for-one-axis gantry machine.
- crisiacuf
07 Jul 2014 23:14 #48499
by crisiacuf
Can you share the wizardry?
And config files?
Replied by crisiacuf on topic Homing a dual-motor-for-one-axis gantry machine.
I returned the config to a normal 3-axis trivial kinematics machine, slaved the Y-axis motors in HAL and made it possible to introduce an offset between the two if desired (offset component between Y axis joints). If measurements prove that squaring the gantry is necessary, I can do that using a bit of wizardry using G38 probe cycles in a G code subroutine to find the references.
Once the machine is up and running I might be interested in trying to find a more structural solution. Synchronised homing would only be a part of that.
- DaBit
- Thank you received: 35
07 Jul 2014 23:20 - 07 Jul 2014 23:21 #48502
by DaBit
Replied by DaBit on topic Homing a dual-motor-for-one-axis gantry machine.
I know you are desperate for an answer, but I already answered that question and posted a link to config files in the topic you started about this...
Last edit: 07 Jul 2014 23:21 by DaBit.
Time to create page: 0.052 seconds
