Mesa 5i25 7i77 0-10v spindle output Dual spindles
- jeeybee
28 Aug 2014 22:37 #50412
by jeeybee
Replied by jeeybee on topic Mesa 5i25 7i77 0-10v spindle output
Ok now it work like it should and here is the code:
setp hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogout4-scalemax 3000
setp hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogout4-minlim 0
setp hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogout4-maxlim 3000
loadrt abs count=1
addf abs.0 servo-thread
net spindle-speed-scale motion.spindle-speed-out => abs.0.in
net positive-only-spindle-speed-cmd abs.0.out => hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogout4
Moving on to add the settings to the INI file.
loadrt abs count=1
- jeeybee
28 Aug 2014 22:42 #50414
by jeeybee
Here are the version with INI settings:
HAL:
setp hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogout4-scalemax [SPINDLE]SCALE_MAX
setp hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogout4-minlim [SPINDLE]MIN_LIMIT
setp hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogout4-maxlim [SPINDLE]MAX_LIMIT
loadrt abs count=1
INI:
[SPINDLE]
MIN_LIMIT = 0.0
MAX_LIMIT = 3000
SCALE_MAX = 3000
HAL:
loadrt abs count=1
INI:
[SPINDLE]
MIN_LIMIT = 0.0
MAX_LIMIT = 3000
SCALE_MAX = 3000
- jeeybee
28 Aug 2014 23:16 #50416
by jeeybee
Stuck again
Iḿ trying to add a second spindle speed with a different scale and everything seem to work until the analog output, which does not give anything out of it?
#Spindle 0-10v
setp hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogout5-scalemax [SPINDLE_2]SCALE_MAX
setp hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogout5-minlim [SPINDLE_2]MIN_LIMIT
setp hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogout5-maxlim [SPINDLE_2]MAX_LIMIT
loadrt abs count=2
addf abs.1 servo-thread
net spindle-speed-scale motion.spindle-speed-out => abs.1.in
net positive-only-spindle2-speed-cmd abs.1.out => hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogout5
#Spindle 0-10v
loadrt abs count=2
- jeeybee
28 Aug 2014 23:41 #50418
by jeeybee
The halmeter actually shows that I have the S value on analogout5 but for some reason it wont give any voltage.
Is this output different from analogout4 and have to be enabled or something?
- Thank you received: 5262
29 Aug 2014 00:17 #50421
Replied by PCW on topic Mesa 5i25 7i77 0-10v spindle output
Yes Analog output 5 is the output intended for spindle use so has a separate enable
- jeeybee
29 Aug 2014 01:51 #50426
by jeeybee
Ok tried this:
#Analogout5 enable
# axis enable chain
newsig emcmot.05.enable bit
sets emcmot.05.enable FALSE
net emcmot.05.enable => axis.5.amp-enable-out
Nothing happens
#Analogout5 enable
# axis enable chain
Nothing happens
29 Aug 2014 02:38 #50428
net spindle-on motion.spindle-on hm2_5i25.0.7i77.0.1.spinena
- jeeybee
29 Aug 2014 13:58 #50442
by jeeybee
Thanks.
Is there somewhere I can read to learn this or is it checking the pins thoroghly and guessing the function?
- cncbasher
- Thank you received: 288
29 Aug 2014 14:14 #50443
by cncbasher
Replied by cncbasher on topic Mesa 5i25 7i77 0-10v spindle output
most is all there in the docs , but things do change , i have even had the same question , so dont fret , just ask if you can't find a soloution , their are quite a few of us willing to help
it's just linuxcnc is so diverse in it's configuration , and covers every permutation .
Dave
Dave
- jeeybee
29 Aug 2014 17:03 #50451
by jeeybee
Ok its a bit frustrating that it seem to be so hard to find the info, seem not to written for beginners at least
Next thing Iḿ having a problem with are M103-M105.
I have created them and put them in the NC files directory as that is the only search patch specified in the INI file.
This is the code for M103:
#!/bin/bash
#Set spindle2 cw output
halcmd setp hm2_[HOSTMOT2](BOARD).0.7i77.0.0.output-04 True
halcmd setp hm2_[HOSTMOT2](BOARD).0.7i77.0.0.output-05 False
exit 0
But nothing happens, no error message and no output?
If I write the code in terminal I get bash: syntax error near unexpected token `('
But if I just put it in my hal file like setp hm2_[HOSTMOT2](BOARD).0.7i77.0.0.output-04 True the output is set at startup so the address seem to be right.
And I have set the permissions for the files so they can be executed
Also what is the #!/bin/bash for?
#!/bin/bash
exit 0
Time to create page: 0.078 seconds
