upgraded from 2.5 to 2.6 tuning issues
19 Dec 2014 05:46 #54151 by PCW
Replied by PCW on topic upgraded from 2.5 to 2.6 tuning issues
Not sure but does oscillation frequency change if you lower P?
Right now it looks like 120 Hz power supply ripple
19 Dec 2014 10:43 #54157 by clkeck1
Replied by clkeck1 on topic upgraded from 2.5 to 2.6 tuning issues
I'm pretty sure the frequency stays the same. I will verify that tomorrow.
If it is a power supply issue I'm assuming it is the encoder and control psu I should be looking at and not the servo psu. The encoders are ttl so they are probably more susceptible to noise.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
19 Dec 2014 11:47 #54159 by Todd Zuercher
Replied by Todd Zuercher on topic upgraded from 2.5 to 2.6 tuning issues
I would think that if the problem were with the encoder you would be seeing drift issues.
What I think Peter is hinting at is something somehow causing a ripple in your analog control signal.
What happens if you back off the P, can you get it to smooth out? You might have to back it off a lot.
20 Dec 2014 03:48 #54168 by clkeck1
As expected this was not a 2.6 issue.
I switched the 12V and 5V channels from the machine power supply to the computer PSU and the issue has went away.
Hmm. I wonder if this had anything to due with the mother board failure??
For all your help
Time to create page: 0.150 seconds
