- Thank you received: 13
This is not quite true. When the auto-rotate button is ON , then after measurement using one of the rotation buttons the coordinate system will automatically rotate by the measured angle and any other probing action would be done in the rotated coordinate system. When the auto-rotate button is OFF , then after measurement using one of the rotation buttons you get the value of the angle without rotating the coordinate system.When the auto-rotate button is ON , than you say that any other probing action would be done in the rotated coordinate system.
