Work with probe
6 years 1 month ago #184171 by RayJr
Replied by RayJr on topic Work with probe
If you don't want to change the probe_screen.py file, you can get around the issue by entering integers in all of the velocity settings.
Ray
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
6 years 1 month ago #184368 by harvey
Replied by harvey on topic Work with probe
Hi Ray
Now I tried it with linuxcnc 3.8
This is the error message i got with float-entry
File "python/probe_screen.py", line 383, in on_btn_jog_pressed
velocity = float(self.inifile.find("TRAJ", "DEFAULT_VELOCITY"))
TypeError: float() argument must be a string or a number
I give it up I will write my own routines. So I could learn a little bit python.
6 years 2 weeks ago #185919 by Mokuleia
Replied by Mokuleia on topic Work with probe
Hi everyone. I am experiencing some issues with running Probe Screen V2 (PSV2) in Gmoccapy 3. Basically, the PSV2 tab is not showing anywhere, although I can see it in Axis when changing DISPLAY from Gmoccapy to Axis in my .ini file. I looked a bit at some of the python scripts and found the following command line in probe_screen.py: def get_display(self): #gmoccapy or axis ? temp = self.inifile.find("DISPLAY", "DISPLAY"), so I presume changing the display from Axis to Gmoccapy should in theory work (or at least it appears that PSV2 developers had that in mind). Did any of you were able to install PSV2 with Gmoccapy successfully? Any idea where to look and what to change to make it work? Thanks
6 years 1 week ago #186847 by depronman
Replied by depronman on topic Work with probe
Hi I have this working perfectly in LinuxCNC V2.8.0 using Gmoccapy GUI
6 years 1 week ago #186849 by Mokuleia
Would you have any tips to share? Did you just follow the written procedure and that was it?
6 years 1 week ago #186850 by depronman
I started with the instructions from github, which work OK for Axis, but would not work with gmoccapy gui
I did a bit of interweb searching and found a post with some alternative instructions for gmoccapy, using these it worked perfectly
I will grab the code tomorrow for you, its on the PC in the workshop and its cold and wet here so not going out to the shop again tonight :)
Paul
Time to create page: 0.093 seconds
