Work with probe
6 years 1 week ago #186935 by depronman
Replied by depronman on topic Work with probe
Hi All,
I've attached my ini and set of HAL files and associated folders
The ini and HAL files are all well documented into section with description comments, so easy to understand at least what parts are doing what tasks
To get the probe stuff working using gmoccapy it was the following that was the key to it in the ini file-
EMBED_TAB_NAME=Probe Screen
EMBED_TAB_LOCATION = ntb_user_tabs
EMBED_TAB_COMMAND = gladevcp -x {XID} -u python/probe_screen.py probe_icons/probe_screen.glade
As against this (which worked perfectly when using the AXIS GUI) -
DISPLAY = axis
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x {XID} -u python/probe_screen.py -H probe_icons/probe_screen.hal probe_icons/probe_screen.glade
My config files support a wifi pendent and control panel jog buttons for X, Y & Z as well as cycle start, stop, step buttons
It utilises a pair of parallel ports, the primary port is an 'out' port and the second port is working in 'in' mode, pine 2,3,4,5,6 & 7 are used for the JOG buttons.
Jog is also possible from the keyboard keys an from the pendent either using the MPG wheel or using the axis selector and macro 6 & macro 7 buttons
The spindle speed is controlled using step and direction pulses plus a relay on pin-17 for spindle start/stop
It is not finished yet, more a work in progress
The following user(s) said Thank You: Mokuleia
5 years 10 months ago #191379 by jimboh2
Replied by jimboh2 on topic Work with probe
@depronman I am very new to linuxcnc and am building a cnc mill. I was having trouble getting the probe screen to display and I copied from your config files. It did not work until I added spaces changing the line EMBED_TAB_NAME=Probe Screen to EMBED_TAB_NAME = Probe Screen. Now it works great. Thank you. I have also purchased a pendant i am waiting to arrive from china. Your config files should be a great help when I come to set that up. Thanks again.
5 years 10 months ago #191390 by depronman
You are more than welcome my friend
Linuxcnc can and is rather pedantic on the syntax of the ini and hal files
Great that my learning curve as helped you in some small way
The probing has proven to be very accurate so far and the pendant is working well
Cheers. Paul
5 years 10 months ago #191400 by alkabal
Replied by alkabal on topic Work with probe
Hi all
You can found Updated version of the probe screen here :
github.com/linuxcnc-probe-screen/probe-screen-ng
Br
5 years 10 months ago #191671 by Roguish
Replied by Roguish on topic Work with probe
thanks for the new version for 2.8.
Linuxcnc is moving from Python 2.0 to Python 3.0.
Is ProbeScreen ready for Python 3.0 ???
I use ProbeScreen every time on my mill.
5 years 10 months ago - 5 years 10 months ago #191694 by alkabal
Hi
I think yes the change are done for python 3.0/
But for now it's better to wait a little (excepted for beta tester or if you want to review or change somehting this is the moment) code is actually ok but some work are on the way.
Br
Last edit: 5 years 10 months ago by alkabal.
Time to create page: 0.163 seconds
