okay, so i changed the toolsensor and change_position variables to be -20 (or something random) and 0 respetively. Things work mostly fine, but there's still a small catch.
i'll run the code, and it moves the spindle to the tool position, and then ask me to insert tool X in. Right now, since i'm not using a tool height sensor but just doing it before running the gcode, I don't have the "Remap M6" box checked on the probe screen.
The problem i'm running into now is that after i click okay saying tool X is installed, the program basically stops. i can get it to run again by refreshing the gcode file or by reopening it, and then running it again. When i do this it moves the spindle to the tool change position, and then goes straight to cutting, i'm assuming because it already knows the i have tool X installed.
Anyone know why this might be happening? Also, while it's running through the remapper program, it highlights the lines of gcode on code that i loaded to cut my piece. so for instance when it gets to line 31 in the remapper code (which moves the spindle to the change position location) it's high lighting my gcode for cutting, which of course are completely different files... could this have something to do with it?
Anyways, It work mostly working now, and it's not a huge hastle to reload the gcode, unless it's a large file, and then it take a minute or so to reparse through it.
thanks for any help!
