I'm not sure if this post is still active/open to questions, or if it'd be better to create a new post, but we'll see.
So last night i installed the probe screen and finally got it all working, but when i tried to run some gcode today, I kept getting a "linear move on line 33 would exceed Z's positive limit". I got this on every gcode file i had made, and had even run some of them before in the past without issue.
each of these files has a Tx M6 command, which is where the problem comes in. something weird is happening in the M6 remmap which i think is causing the problem. If i remove the Tx M6 line, the program runs just fine, but i'd like to keep it in there and fix the problem for when I have gcodes that do that tool change commands in them.
Is anyone else having a similar issue? I've attached my .ini and .hal files incase that helps, but can provide other files if needed to. Thanks for the help!
