Work with probe
5 years 8 months ago #198255 by andypugh
Replied by andypugh on topic Work with probe
Looking in the glade file:
github.com/verser-git/probe_screen_v2/bl...e_screen.glade#L1117
The jog buttons should call the handler "on_btn_jog_pressed"
This should be handled in the python file:
github.com/verser-git/probe_screen_v2/bl...probe_screen.py#L360
That contains a comment about being in manual mode. Which GUI are you using? Some make manual mode more obvious than others.
I would be tempted to add a tell-tale in on_btn_pressed to make sure that the routine is called. something like "print("somebody pressed my buttons")" right after the def command, and indented the same as the self.command.mode line.
(Though I think you would need to start linuxcnc from the command line to _see_ the output of the print command. If you don't know how to do that, just open a terminal and type "linuxcnc")
  • CBollweg
  • New Member
  • New Member
5 years 8 months ago #198387 by CBollweg
Replied by CBollweg on topic Work with probe
Hi andy,
thanks for your answer. When i start linuxcnc in the terminal i get:
/usr/lib/python2.7/dist-packages/gladevcp/tooledit_widget.py:64: GtkWarning: Invalid input string
self.wTree.add_from_file(os.path.join(datadir, "tooledit_gtk.glade") )
/usr/lib/python2.7/dist-packages/gladevcp/tooledit_widget.py:401: GtkWarning: Invalid input string
renderer.set_property('visible', bool)
**** probe_screen GETINIINFO ****
Preference file path: /home/hafven/linuxcnc/configs/Backup/probescreen_axis/probescreen_axis.pref
**** PROBE SCREEN INFO ****
**** To many increments given in INI File for this screen ****
**** Only the first 5 will be reachable through this screen ****
46137347
toolnumber = 0 False
  • CBollweg
  • New Member
  • New Member
5 years 8 months ago #198388 by CBollweg
Using the axis gui.
Also using a xhc-whb04-06. May that course Problems ?
5 years 8 months ago #198389 by andypugh
Did you add a debug print to the Python handler? And is anything printed when you press the button?
It is _possible_ that the too-many-increments is breaking it.
5 years 8 months ago #198390 by alkabal
Replied by alkabal on topic Work with probe
Maybe you can try revised version :
github.com/alkabal/probe-screen-ng
or
github.com/linuxcnc-probe-screen/probe-screen-ng
Yes you need to have less than 5 value for jog increment in you ini file
[DISPLAY]
INCREMENTS = 1mm .1mm .05mm .01mm .001mm
I also use a XHC-WHB04b-6 with revised probe screen.
  • CBollweg
  • New Member
  • New Member
5 years 8 months ago #198392 by CBollweg
ok, i had 7 Increments. Changed this an will try later on
Time to create page: 0.647 seconds
