Work with probe
5 years 7 months ago #202485 by andypugh
Replied by andypugh on topic Work with probe
Cam_Haug wrote: Has anyone solved the issue in psng probe screen on 2.8 where at the tool change prompt it simply stops and you have to reload?
Do you have a link in HAL between iocontrol.0.tool-change and iocontrol.0.tool-changed? And the same for tool-prep
5 years 7 months ago #202533 by Cam_Haug
Replied by Cam_Haug on topic Work with probe
Is there a further link I need to create than what is in the psng.hal file?
# Ensure all toolchange pins are free to use
unlinkp iocontrol.0.tool-number
unlinkp iocontrol.0.tool-prep-number
unlinkp iocontrol.0.tool-change
unlinkp iocontrol.0.tool-changed
unlinkp iocontrol.0.tool-prepare
unlinkp iocontrol.0.tool-prepared
net tool-change probe.toolchange-change <= iocontrol.0.tool-change
net tool-changed probe.toolchange-changed => iocontrol.0.tool-changed
net tool-number probe.toolchange-number <= iocontrol.0.tool-number
net tool-prep-number probe.toolchange-prep-number <= iocontrol.0.tool-prep-number
net tool-prep-loop iocontrol.0.tool-prepare <= iocontrol.0.tool-prepared
5 years 7 months ago - 5 years 7 months ago #202564 by zu4lu
Replied by zu4lu on topic Work with probe
Hi, same problem. After clicking ok, nothing happens. If i'm waiting long enough, message window is popping up: "it is not possible to change to Auto Mode at the moment". Latest psng code from git.
Last edit: 5 years 7 months ago by zu4lu.
5 years 6 months ago #207323 by Roguish
Replied by Roguish on topic Work with probe
What is the status of your update version?
done?
when release?
5 years 5 months ago #208416 by kotlikm
Replied by kotlikm on topic Work with probe
Hoping i can get some help, I have everything setup and running with my probe screen, however when i run a tool change, ie, T2 M6, my machine runs to my tool change location, and then no further actions are taken from there, no option to confirm that i have put in T2.
5 years 5 months ago #208423 by andypugh
kotlikm wrote: T2 M6, my machine runs to my tool change location, and then no further actions are taken from there, no option to confirm that i have put in T2.
It sounds like you probably need to set up hal_manualtoolchange of you don't have an automatic toolchanger to toggle the inputs automatically.
linuxcnc.org/docs/2.8/html/man/man1/hal_manualtoolchange.1.html
Time to create page: 0.357 seconds
