Work with probe
5 years 5 months ago - 5 years 5 months ago #208541 by kotlikm
Replied by kotlikm on topic Work with probe
newbynobi wrote: Sound for me like you haven't closed the tool prepare loop.
Are you using Hal-manual tool chage or the tool change dialog from gmoccapy?
If you post your config, it might be possible to give better recommendations.
Norbert
I guess this is where I am struggling. All of the installation instructions for probe screen tell you to comment out the "Hal-manual tool change" in the HAL file. Any further insight you can provide would be really appreciated.
thanks
File Name: Mitchell_P...5-11.hal
File Size:13.64 KB
File Name: Mitchell_PNC.ini
File Size:6.35 KB
File Name: psng.hal
File Size:681 B
Last edit: 5 years 5 months ago by kotlikm.
5 years 5 months ago #208595 by andypugh
Replied by andypugh on topic Work with probe
kotlikm wrote: Interesting, all the instructions for setting up probe screen tell you to comment that line set out of the .hal
Yes, but they also add the semi-equivalent:
github.com/linuxcnc-probe-screen/probe-s...master/psng/psng.hal
Did you add a reference to psng.hal in your INI file?
5 years 5 months ago - 5 years 5 months ago #208596 by kotlikm
It's called out in the EMBED_TAB_COMMAND in the display section of the .ini as the instructions reference.
Plus I can see on the hal Meter that atleast my change and changed pins turn true when running the macros.
5 years 5 months ago #208652 by andypugh
If tool-changed follows tool-change then it all should work.
Is there an M1 (pause) command in the G-code around the tool change? Some post-processors like to do that.
5 years 5 months ago #208672 by kotlikm
Nope, not an M1, I've decided to drop trying to get probe screen to work for the tool change at this point, needs more work than I am capable of. Found an older thread using just a remapped M6 and M600 macro that is already working much better, just need to get travels all dialed in.
Thanks for all the help trying to get it working though.
5 years 4 months ago - 5 years 4 months ago #212007 by MLc
Replied by MLc on topic Work with probe
Hello guys, I want to ask if it possible run this probe screen on OrangePi linuxcnc from MXmaster. I try it but I have problems. I did it according to the manual. Here is my config files for check. (This is my test config where I tested the probe screen. If it will work I add it to my config which I use)
I use this probe screen: github.com/linuxcnc-probe-screen/probe-s...-ng/tree/master/psng
Thank you for answer :)
Martin
EDIT:
I fix the problem, linuxcnc run but the window ''PSNG'' didn't show any icons.
Last edit: 5 years 4 months ago by MLc.
Time to create page: 0.676 seconds
