Work with probe
5 years 5 months ago #208424 by kotlikm
Replied by kotlikm on topic Work with probe
So, odd thing is, if i comment out the M6 code on line 30 of the "manual_change.ngc" macro, it appears to run fine, but doesnt give me a pause or anything to ackwoledge that i have put a new tool in the spindle.
5 years 5 months ago #208425 by kotlikm
Interesting, all the instructions for setting up probe screen tell you to comment that line set out of the .hal
5 years 5 months ago - 5 years 5 months ago #208428 by kotlikm
The installation instructions for the probe screen have the following;
4. Delete (or comment out) from all .hal files lines of the form:
#loadusr -W hal_manualtoolchange
#net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
#net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
#net tool-number iocontrol.0.tool-prep-number
Any recommendations for what should be left in?
Last edit: 5 years 5 months ago by kotlikm.
5 years 5 months ago #208445 by kotlikm
I've got the following in my configuration which I assume would have me covered.
In probe_screen.hal:
net tool-change probe.toolchange-change <= iocontrol.0.tool-change
net tool-changed probe.toolchange-changed <= iocontrol.0.tool-changed
net tool-prep-number probe.toolchange-number <= iocontrol.0.tool-prep-number
In my main .hal:
net tool-prep-loop iocontrol.0.tool-prepare <= iocontrol.0.tool-prepared
5 years 5 months ago - 5 years 5 months ago #208508 by kotlikm
So I got most of it working using the latest probe screen "next generation" .
github.com/linuxcnc-probe-screen/probe-screen-ng
However I'm running into one last weird issue.
When I run a program, I get the pop up to load the tool, and when I press OK, nothing happens. It shows the manual tool change macro is loaded, but it doesn't continue and run over to the tool setter to touch off the new tool. The weird thing is, if I rerun the intended .ngc program, it will go over to the tool setter as desired, and then run the program, until it gets to the next tool change and the stops running after I swap in a new tool and press ok.
I am using GMOCCAPY if that makes a difference, there doesn't seem to be much if any documentation on setting up with this GUI vs AXIS.
5 years 5 months ago #208521 by newbynobi
Replied by newbynobi on topic Work with probe
Sound for me like you haven't closed the tool prepare loop.
Are you using Hal-manual tool chage or the tool change dialog from gmoccapy?
If you post your config, it might be possible to give better recommendations.
Norbert
Time to create page: 0.761 seconds
