Hi all, I managed to start the linuxcnc from command line. Here is the terminal log:
Found file(REL): ./config.hal
Note: Using POSIX realtime
note: MAXV max: 100.000 units/sec 6000.000 units/min
note: LJOG max: 100.000 units/sec 6000.000 units/min
note: LJOG default: 5.000 units/sec 300.000 units/min
note: jog_order='XYZ'
note: jog_invert=set([])
Unexpected realtime delay on task 0 with period 200000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
Gtk-Message: 08:48:27.898: Failed to load module "gail"
** (gladevcp:3711): WARNING **: 08:48:27.989: (../atk-adaptor/bridge.c:993):atk_bridge_adaptor_init: runtime check failed: (root)
File "/usr/bin/gladevcp", line 46, in <module>
import gladevcp.makepins
File "/usr/lib/python2.7/dist-packages/gladevcp/__init__.py", line 1, in <module>
from hal_pythonplugin import *
File "/usr/lib/python2.7/dist-packages/gladevcp/hal_pythonplugin.py", line 42, in <module>
from hal_sourceview import *
File "/usr/lib/python2.7/dist-packages/gladevcp/hal_sourceview.py", line 27, in <module>
import gtksourceview2 as gtksourceview
ImportError: No module named gtksourceview2
Any solutions? (I run linux on OrangePi) I tried to configure machine settings on my old thinkpad with LPT port and the probe screen working..
Thanks Martin
EDIT: I fixed it. Gtksourceview2 was missing. After instalation probe screen working.
