Work with probe
  • REX299
  • New Member
  • New Member
5 years 2 months ago #216887 by REX299
Replied by REX299 on topic Work with probe
Hi
Does it work with Linux 2.9pre? I installed but it show blank sceen on probe tab. Should i can do to fix it. Thanks.
5 years 2 months ago #218743 by Roguish
Replied by Roguish on topic Work with probe
sounds like you do not have all the files and directories in the correct locations, as it's not finding the icons, etc...
check all the instructions very carefully......
been there before....
be sure to have the proper sections in your .ini
[TOOLSENSOR]
[CHANGE_POSITION]
[PYTHON]
and the 2 lines if you are embedding it.
good luck.
RTFM
5 years 2 months ago #218775 by zieluch
Replied by zieluch on topic Work with probe
kotlikm wrote: Interesting, all the instructions for setting up probe screen tell you to comment that line set out of the .hal
Yes, but they also add the semi-equivalent:
github.com/linuxcnc-probe-screen/probe-s...master/psng/psng.hal
Did you add a reference to psng.hal in your INI file?
Hi Andy,
I run in the similar problem. When I forgot to add psng.hal file into ini remapped m06 tX command will move into tool change position, pop up window appear on the screen and once I select ok that tool is changed nothing happened.
Once I added psng.hal into ini my machine is not opening at all and I am getting error Pin probe.toolchange-change doesn't exist. When i comment section from line 9 in psng.hal related to tool change I able to start the machine and when i checking hal meter I can see exactly pin probe.toolchange and others except one from the file which confuse me. Do you have an idea what is going on there ?
5 years 1 month ago #219455 by Roguish
are you on 2.8 or 2.9-pre ????
I tried to update from 2.8 to 2.9-pre and probe-screen failed on the glade load......
went back to 2.8
5 years 1 month ago #220399 by zieluch
I am using 2.8 linux cnc. I think I tried eveything but nothing works there. Is anyone able to help me ?
5 years 1 month ago - 5 years 1 month ago #221448 by Jasper 3
Replied by Jasper 3 on topic Work with probe
Hey, first of all the screen is amazing! I think I will make some changes but first of all I need to get the Toolchange done.after reading all 49 sites i found out that many users have the same problem. But I didnt found a solution.My problem is after i changed the tool the machine isnt do any thing. In the Halmeter I can see that tool changed doesn't turn on.It would be great if any one could help me out!
File Name: Linuxcnc_P...aese.zip
File Size:938.59 KB
Last edit: 5 years 1 month ago by Jasper 3.
Time to create page: 0.108 seconds
