Work with probe
09 Feb 2021 20:52 #198199
Replied by andypugh on topic Work with probe
Are you homed?
- CBollweg
- Visitor
09 Feb 2021 22:12 #198206
by CBollweg
Replied by CBollweg on topic Work with probe
Of course
09 Feb 2021 22:25 #198208
I don't know, then.
I guess you can jog the machine normally, but the buttons on the probe screen don't work?
- CBollweg
- Visitor
10 Feb 2021 00:23 #198228
by CBollweg
Yes, joging is possible, only the buttons on the probe screen don't work.
10 Feb 2021 09:32 #198255
Looking in the glade file:
github.com/verser-git/probe_screen_v2/bl...e_screen.glade#L1117
The jog buttons should call the handler "on_btn_jog_pressed"
This should be handled in the python file:
github.com/verser-git/probe_screen_v2/bl...probe_screen.py#L360
That contains a comment about being in manual mode. Which GUI are you using? Some make manual mode more obvious than others.
I would be tempted to add a tell-tale in on_btn_pressed to make sure that the routine is called. something like "print("somebody pressed my buttons")" right after the def command, and indented the same as the self.command.mode line.
(Though I think you would need to start linuxcnc from the command line to _see_ the output of the print command. If you don't know how to do that, just open a terminal and type "linuxcnc")
- CBollweg
- Visitor
11 Feb 2021 12:51 #198387
by CBollweg
Hi andy,
thanks for your answer. When i start linuxcnc in the terminal i get:
/usr/lib/python2.7/dist-packages/gladevcp/tooledit_widget.py:64: GtkWarning: Invalid input string
self.wTree.add_from_file(os.path.join(datadir, "tooledit_gtk.glade") )
/usr/lib/python2.7/dist-packages/gladevcp/tooledit_widget.py:401: GtkWarning: Invalid input string
renderer.set_property('visible', bool)
**** probe_screen GETINIINFO ****
Preference file path: /home/hafven/linuxcnc/configs/Backup/probescreen_axis/probescreen_axis.pref
**** PROBE SCREEN INFO ****
**** To many increments given in INI File for this screen ****
**** Only the first 5 will be reachable through this screen ****
46137347
toolnumber = 0 False
46137347
- CBollweg
- Visitor
11 Feb 2021 12:57 #198388
by CBollweg
Using the axis gui.
Also using a xhc-whb04-06. May that course Problems ?
11 Feb 2021 13:06 #198389
Did you add a debug print to the Python handler? And is anything printed when you press the button?
It is _possible_ that the too-many-increments is breaking it.
- alkabal
- Thank you received: 52
11 Feb 2021 13:14 #198390
by alkabal
Replied by alkabal on topic Work with probe
Maybe you can try revised version :
github.com/alkabal/probe-screen-ng
or
github.com/linuxcnc-probe-screen/probe-screen-ng
Yes you need to have less than 5 value for jog increment in you ini file
[DISPLAY]
INCREMENTS = 1mm .1mm .05mm .01mm .001mm
I also use a XHC-WHB04b-6 with revised probe screen.
or
[DISPLAY]
- CBollweg
- Visitor
11 Feb 2021 13:30 #198392
by CBollweg
ok, i had 7 Increments. Changed this an will try later on
Time to create page: 0.342 seconds
