parport tester
- allenwg2005
- Thank you received: 4
10 Sep 2015 23:24 #62404
by allenwg2005
parport tester was created by allenwg2005
Can someone point me to a parport tester that will work with a 2.7 config.
I think a netmod or xmod should work.
- Thank you received: 4992
11 Sep 2015 19:32 #62449
Replied by andypugh on topic parport tester
- allenwg2005
11 Sep 2015 20:27 - 11 Sep 2015 20:28 #62458
by allenwg2005
Replied by allenwg2005 on topic parport tester
Saved the two files to my Desktop, opened a terminal and typed halrun -I -f ptest.hal.
This was the outcome, what went wrong??
~/Desktop$ halrun -I -f ptest.hal
Could not open command file 'ptest.hal'
halcmd:
halcmd:
Last edit: 11 Sep 2015 20:28 by allenwg2005.
11 Sep 2015 20:54 #62461
I don't know if the file needs to be executable?
You can do it another way
halrun
source ptest.hal
halrun
source ptest.hal
The following user(s) said Thank You: allenwg2005
- dgarrett
- Thank you received: 325
11 Sep 2015 21:08 - 11 Sep 2015 21:15 #62465
by dgarrett
Replied by dgarrett on topic parport tester
Last edit: 11 Sep 2015 21:15 by dgarrett.
- cncbasher
- Thank you received: 288
11 Sep 2015 23:46 - 11 Sep 2015 23:47 #62473
by cncbasher
Replied by cncbasher on topic parport tester
Allen,
the parport tester will need to be modified to work with pci cards , it is only set for the 2 standard default parports
dewey:
would be nice to have an option to insert a parport address if not using the default
dewey:
Last edit: 11 Sep 2015 23:47 by cncbasher.
- dgarrett
12 Sep 2015 06:47 #62486
by dgarrett
patch to add a script named parport_try.demo to the configs/apps/parport menu
(enter an integer port number)
- BigJohnT
- Thank you received: 1176
12 Sep 2015 18:10 #62494
by BigJohnT
Replied by BigJohnT on topic parport tester
Not knowing what to pick I just ran Ox278 and it crashed my computer, after rebooting I ran Ox378 and that worked. I wonder if the parallel port checker needs some smarts?
JT
JT
- BigJohnT
12 Sep 2015 18:21 - 12 Sep 2015 18:38 #62496
by BigJohnT
I just went to the wiki and saved the two files to my desktop then opened a terminal and ran the parallel port tester without any problem. So I then checked the permissions on the two files and they were read/write for me and read only for others and execute was not checked.
Edit: when I tried to run from the wrong directory I got the "Could not open command file 'ptest.hal'.
JT
halcmd:
JT
Last edit: 12 Sep 2015 18:38 by BigJohnT.
- allenwg2005
12 Sep 2015 22:54 #62499
by allenwg2005
JT, Yup it was "permission".
I have tried the port testers in 2.7.0, I have also ran the tester from a terminal, I get nothing on 0x278 or 0x378.
This is a (new to me) PC I have just acquired, it has no LPT port on the Mboard.
I installed the two pci cards from my LCNC 8.04 Harty 2.5.4 PC in it.
LCNC 2.7 will start, I get an error "Joint 2 on limit switch", (the sim worked should that matter).
I've tried all the addresses in o2:01.0 below, no joy. (Joint 2 being assigned to that port in my Hal).
How do I find the addresses for these cards?
Or is something else going on here?
Out-put from lspci -v:
02:00.0 Communication controller: Device 5372:6872 (rev 01)
Subsystem: LSI Logic / Symbios Logic Device 0012
Flags: slow devsel, IRQ 4
I/O ports at df00
I/O ports at de00
I/O ports at dd00
I/O ports at dc00
I/O ports at db00
I/O ports at da00
02:01.0 Communication controller: Device 5372:6872 (rev 01)
Flags: slow devsel, IRQ 5
I/O ports at d900
I/O ports at d800
I/O ports at d700
I/O ports at d600
I/O ports at d500
I/O ports at d400
I/O ports at df00
I/O ports at de00
I/O ports at dd00
I/O ports at dc00
I/O ports at db00
I/O ports at da00
I/O ports at d900
I/O ports at d800
I/O ports at d700
I/O ports at d600
I/O ports at d500
I/O ports at d400
Time to create page: 0.087 seconds
