parport tester
12 Sep 2015 23:50 #62500 by andypugh
Replied by andypugh on topic parport tester
try cat /proc/ioports
The following user(s) said Thank You: allenwg2005
  • allenwg2005
  • allenwg2005's Avatar Topic Author
  • Elite Member
  • Elite Member
13 Sep 2015 00:18 #62501 by allenwg2005
Replied by allenwg2005 on topic parport tester
cat results
13 Sep 2015 00:26 #62502 by andypugh
Nothing leaps out, normally something says "parallel port"
You could try the pnp devices, 0400 and 0800 might be worth a try, possibly even 04d0.
  • allenwg2005
  • Elite Member
  • Elite Member
13 Sep 2015 00:40 #62503 by allenwg2005
It's certainly worth a try.
Just so I'm not wasting anyones time, exactly how should I enter that in my hal?
What I have now:
loadrt hal_parport cfg="0x378 out 0xdf00 out 0xd900 out"
Should it be:
loadrt hal_parport cfg="0x378 out 0x0400 out 0x0800 out"??
Thanks for the help.
  • allenwg2005
  • Elite Member
  • Elite Member
13 Sep 2015 01:25 #62505 by allenwg2005
I have forward movement. (I think).
I made the following change to the hal:
loadrt hal_parport cfg="0x378 out 0xc000 out 0xd000 out"
LCNC loads, I can F1, F2, (first time F2 cleared).
When I try and "Home" the tool cone starts looking for Z home in the wrong direction on the Axis screen, Z on the machine isn't doing a thing
The port tester won't work do to the unusual port address (I suppose).
Can anyone help?
13 Sep 2015 02:08 #62506 by andypugh
It can be made to. It is based around a simple HAL file, which has exactly the same loadrt hal_parport line as your machine HAL file.
Test the extra ports one at a time by trying the addresses.
  • allenwg2005
  • Elite Member
  • Elite Member
13 Sep 2015 08:18 - 13 Sep 2015 08:19 #62510 by allenwg2005
This is the "loadrt hal_parport cfg="0x378 out" line in ptest.hal.
Given the port arrangement of my PC (no LPT port on Mboard), should I eliminate "0x378" from the line?
Could someone please illustrate what the line should look like given the addresses below and the PCI set-up I seem to have.
Thank you.
0cf8-0cff : PCI conf1
c000-cfff : PCI Bus 0000:01
d000-dfff : PCI Bus 0000:02
d400-d40f : 0000:02:01.0
d500-d507 : 0000:02:01.0
d600-d607 : 0000:02:01.0
d700-d707 : 0000:02:01.0
d800-d807 : 0000:02:01.0
d900-d907 : 0000:02:01.0
da00-da0f : 0000:02:00.0
db00-db07 : 0000:02:00.0
dc00-dc07 : 0000:02:00.0
dd00-dd07 : 0000:02:00.0
de00-de07 : 0000:02:00.0
df00-df07 : 0000:02:00.0
Last edit: 13 Sep 2015 08:19 by allenwg2005.
13 Sep 2015 08:21 #62511 by andypugh
You should only use addresses of ports that correspond to an actual parallel port.
You can use the p-port tester to find out which ports have a parallel port on them. One at a time.
  • Moderator
  • Moderator
14 Sep 2015 02:53 #62524 by tommylight
Replied by tommylight on topic parport tester
Instead of this
you shoud have this:
loadrt hal_parport cfg="0dd00 out 0d700 out"
also in the hal file you should have something like :
addf parport.0.write base thread
etc
you must add the same thing for the other parport or it will not work
addf parport.1.read base-thread
addf parport.1.write base thread
Regards,
tom
14 Sep 2015 23:22 #62571 by andypugh
Also, you could try letting Linux find the parports.
loadrt hal_parport config="0 out"
Should find the first parport automatically.
loadrt hal_parport config="0 out 1 out"
Should find both. It doesn't take long to try it.
Time to create page: 0.071 seconds
