2 motors for the same axis
10 years 11 months ago - 10 years 11 months ago #65128 by andypugh
Replied by andypugh on topic 2 motors for the same axis
Can you go into Machine->Show HAL config and check the Signals
xpos-cmd, xpos-fb
apos-cmd, apos-fb?
Last edit: 10 years 11 months ago by andypugh.
10 years 11 months ago #65129 by andypugh
Looking here:
linuxcnc.org/docs/html/man/man9/gantrykins.9.html
I wonder what this means, in practice?
In the inverse kinematics, each joint gets the value of its corresponding axis. In the forward kinematics, each axis gets the value of the highest numbered corresponding joint. For example, with coordinates=XYYZ the Y axis position comes from joint 2, not joint 1.
10 years 11 months ago #65130 by andypugh
andypugh wrote: I wonder what this means, in practice?
This sort-of makes sense. There are two X-feedbacks from two (different) stepgens and only one can be compared to the internal X value.
Try short-circuiting the axis.0 feedback, like this: (ie comment out the stepgen and send the command back as feedback)
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd #net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb net xpos-cmd axis.0.motor-pos-fb
6 years 8 months ago #156688 by Arro
Replied by Arro on topic 2 motors for the same axis
I have a similar problem with axis definition.
I was able to configure a tandem axis (X or Y) in "world-mode".
Now when I define a "tandem-axis" the system sets directly the "joint-mode" and I cannot set it back to world-mode with view-panel.
does anybody know about some wrong settings somewhere ?
6 years 8 months ago #156693 by tommylight
Replied by tommylight on topic 2 motors for the same axis
Can you please attach the hal and ini files so we can have a look ?
6 years 7 months ago #159386 by Arro
It has to do with the ohming
One time you perform the ohming for all axis the system turns into world-mode
Time to create page: 0.260 seconds
