2 motors for the same axis
11 years 1 day ago #64507
sourceforge.net/p/emc/mailman/emc-users/....com.au/#msg28307696
If you look under the message titles one of them has a patch file, and other messages say how to use it.
Alternatively I can imagine that a simple userspace HAL component could watch for all the axis.N.is-homed pins going to "true" and issue a command to enter world mode. That may already have been done too.
Replied by andypugh on topic 2 motors for the same axis
Yes, that is correct. The other side of this is that if you home the Joints separately then there is likely to be a moment when the two sides of the X axis are heading in different directions. Homing slaved axes (especially to encoder index) in a truly general manner is a puzzle that has defied easy solution so far.Gloup wrote: With routing step-dir signal: it's seems to be the easy way. But As I undestand this is a non sense to have limit switch on both X axis. And if I have a jump of step on an axis, I will need to recalibrate manually the position of axis. Is it correct ?
It has been done as a modification to the Axis GUI, but I don't know how well it works.In case of gantrykins. Do you know if a person has already do a script to switch automatically to "Word mode" after homing. Or maybe if it's possible to add on the PyVCP panel a message to "alert" or give the state of this mode ? Because I'm sure I will forget it each time !
The following user(s) said Thank You: Gloup
- Gloup
11 years 1 day ago #64509
by Gloup
Replied by Gloup on topic 2 motors for the same axis
I will read all these things. Thank you
- Gloup
10 years 11 months ago #65112
by Gloup
Hello,
I'm back to you because I'm always trying to work my machine without success.
Regarding the example, I modify my conf.ini. For me it seems ok. I can switch the 2 mode with $ and make the home position. But I have a joint error when I want to use in manual.
I haven't modify the hal file except for "loadrt gantrykins coordinates=XYZX" because I really don't understand what I have to do.
Could you help me again ?
10 years 11 months ago #65119
[quote="Gloup" post=65112I have a joint error when I want to use in manual. [/quote]
What is the exact error message?
- Gloup
10 years 11 months ago #65125
by Gloup
Hello,
When I launch Linux Cnc, on axis, I don't have X, Y, Z, but 0, 1, 2. I guess this is normal.
I can request an origin on all axis :
- First Z, this is OK
- Second X and X(A) : this is OK. Two axis stop on their own switch limit
- Third, Y, this is OK
- cncbasher
- Thank you received: 202
10 years 11 months ago #65127
by cncbasher
Replied by cncbasher on topic 2 motors for the same axis
at least you managed to switch from world mode ,
look in your ini for the follow error values per axis and increase the min follow error to say 0.5
Time to create page: 0.209 seconds
