W axis with gantry kins hal/ini configuration
10 years 10 months ago #66634 by guymalpass
I see, so may this be a bug rather than a config error? Back to Andy's post, yes all the conditions are true. Also if you were to build a Joints_Axes branch wouldn't you use gentrivkins rather than gantrykins?
10 years 10 months ago - 10 years 10 months ago #66639 by dgarrett
For anyone interested in trying a recent joints_axes9 branch,
the attached tar file (g.tgz) has a simplified sim config with:
X --> Joint0
Y --> Joint1 AND Joint2
Z --> Joint3
W --> Joint4
Important notes:
[TRAJ] COORDINATES = XYZW # The [TRAJ]COORDINATES item names the letters for gcode # XYYZW or YYXZW or WXYYYYYYYYYYYZW work the same [KINS] JOINTS = 5 KINEMATICS = gentrivkins coordinates=xyyzw kinstype=BOTH AUTO_TELEOP=20 # The coordinates=xyyzw for gentrivkins assigns to joints # in sequence: 0,1,2,3,4 # so here the order and axis names are important
The AUTO_TELEOP option causes a switch to teleop (world)
after homing (wait 20 seconds at most)
In the axis gui, the '$' character toggles joint and teleop modes
Last edit: 10 years 10 months ago by dgarrett.
10 years 10 months ago #66643 by guymalpass
Thanks for that, I'll have a go with JA9 tomorrow and report back. I think a working gentrivkins is preferable to gantrykins, ignoring soft limits scares the hell out of me!
10 years 10 months ago #66646 by guymalpass
Could you also please tell me what KINSTYPE=BOTH does? I can't seem to find anything out about it.
10 years 10 months ago #66647 by andypugh
guymalpass wrote: Could you also please tell me what KINSTYPE=BOTH does? I can't seem to find anything out about it.
There is a hint here:
github.com/jepler/linuxcnc-mirror/blob/m...otion/kinematics.txt
Though not its use as a module parameter.
10 years 10 months ago #66648 by dgarrett
The code is basically identical for gantrykins and gentrivkins.
I don't know the reason for both or the naming history.
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...s/heads/joints_axes9
man page:
buildbot.linuxcnc.org/doc/scratch/v2.8.0...man/man9/kins.9.html
In joints_axes9, gentrivkins has a (new) module parameter
kinstype for testing. It makes it possible to test a simple
kinematics module as if it were a more complex
(non-identiry) kinematics type.
I used it in the example to illustrate switching between
joint and teleop mode so that you can see the pos-cmds for
both modes in the included halshow gui.
Some guis (axis for example) suppress joint/world switching
for identity kins. In the g.tgz example, remove the text
'kinstype=BOTH' to see the gui behavior for kinematics that
are strictly identity.
Time to create page: 0.416 seconds
