W axis with gantry kins hal/ini configuration
10 years 10 months ago #66651 by andypugh
dgarrett wrote: The code is basically identical for gantrykins and gentrivkins.
I don't know the reason for both or the naming history.
Gentrivkins is intended as a kinematics that allows free mapping of joints to axes but declares kinematics_identity and so does not expose the complications of joint/world mode.
I _think_ it still allows homing in joint mode.
10 years 10 months ago - 10 years 10 months ago #66683 by guymalpass
I've built JA9, configured with gentrivkins and everything is working perfectly! Gantry auto-squaring, obeyed soft limits and automatic teleop are exactly what I was after, thanks Todd, Dewey and Andy for your help with this. I expect the problem remains with gantrykins and non JA builds but I much prefer this setup.
Last edit: 10 years 10 months ago by guymalpass.
10 years 10 months ago #66747 by mozmck
Would you mind sharing your config? I need to set up a gantry with auto-squaring myself.
10 years 10 months ago #66829 by blacksmith
mozmck wrote: Would you mind sharing your config? I need to set up a gantry with auto-squaring myself.
Does the author of the Joints branch have any sample configs?
LCNC is like the punishment of Tantalus. ;)
10 years 10 months ago - 10 years 10 months ago #66830 by andypugh
blacksmith wrote: Does the author of the Joints branch have any sample configs?
If you install the branch, then most of the configs work I believe.
Details: sourceforge.net/p/emc/mailman/message/34685502/
Last edit: 10 years 10 months ago by andypugh.
10 years 10 months ago #66831 by guymalpass
I can post my config files later tonight for you
Time to create page: 0.087 seconds
