7i43 with 7i48 and 7i34
29 Jan 2016 19:09 #69256 by PCW
Replied by PCW on topic 7i43 with 7i48 and 7i34
Are you sure you have the correct 7I43 configuration and pinout for sserial on the 7I34?
What does
sudo mesaflash --device 7I43 --epp --addr 0x378 --program yourbitfile.bit
sudo mesaflash --device 7i43 --epp --addr 0x378 --readhmid
( with the 0x378 address and "yourbitfile.bit" changed to match your setup )
print?
post the printout here by running:
sudo mesaflash --device 7i43 --epp --addr 0x378 --readhmid > mypinout.txt
and posting mypinout.txt here
31 Jan 2016 12:12 #69325 by ioiotutu
Replied by ioiotutu on topic 7i43 with 7i48 and 7i34
Ok, thanks.
I will try it in the next few days and i'll send you back the informations.
Time to create page: 0.133 seconds
