What type of wire to connect stepers
- gizmo6023
07 Mar 2016 13:26 #71177
by gizmo6023
What type of wire to connect stepers was created by gizmo6023
What type of wire is needed to connect steppers to the driver boards? shielded, non shielded ? I am using 18Ga automotive hook up wire for now just to get my machine operational.
- Clive S
- Thank you received: 486
07 Mar 2016 13:49 #71180
by Clive S
size
Replied by Clive S on topic What type of wire to connect stepers
I would use CY 4core 1mm. For nema 23What type of wire is needed to connect steppers to the driver boards? shielded, non shielded ? I am using 18Ga automotive hook up wire for now just to get my machine operational.
size
The following user(s) said Thank You: gizmo6023
08 Mar 2016 06:51 - 08 Mar 2016 06:51 #71213
Replied by andypugh on topic What type of wire to connect stepers
Almost anything will work. It doesn't need to be shielded for the stepper motors, but it might help to reduce radiated noise to the other components.
If the wire runs in a drag-chain you might want to consider flexibility. Oil resistance might be important too (coolant can basically be considered the same as oil, I think). In that case consider Ölflex
Rapid sell it by the meter. www.rapidonline.com/drag-chain-cable.
Last edit: 08 Mar 2016 06:51 by andypugh.
The following user(s) said Thank You: Amedee, gizmo6023
- gizmo6023
09 Mar 2016 21:09 #71303
by gizmo6023
Replied by gizmo6023 on topic What type of wire to connect stepers
Thank you both for the information, I hope shipping from the UK is reasonable.
I have searched for comparable products in the US and found nothing that is reasonably priced.
- Thank you received: 1482
10 Mar 2016 07:28 #71330
Replied by Todd Zuercher on topic What type of wire to connect stepers
We've bought cable from these guys, and the prices shipped to the US was pretty reasonable, for high quality cables.
www.igus.com/chainflex
But the number of choices can be a little daunting.
10 Mar 2016 08:28 #71337
Where are you based? There has to be a local supplier.
You can even order directly from Lapp here:
lapplimited.lappgroup.com/products/onlin...-classic-fd-810.html
It defaults to 50m, but let me select a different length (10m) and wanted £16 for it. Then I needed to create an account, so stopped experimenting.
You could even try eBay. You quite often see the remainders of full reels being old there.
www.ebay.com/itm/Lapp-Kabel-OLFLEX-Oil-R...6:g:aKIAAOxyu1BTk2bi
As an example.
As an example.
- gizmo6023
11 Mar 2016 15:05 #71449
by gizmo6023
California UAS
11 Mar 2016 15:13 #71451
where does the Lapp Group link take you? I ended up at a UK site, but I think that was the system being clever.
California UAS
- gizmo6023
11 Mar 2016 18:59 #71460
by gizmo6023
I also get the UK site, had a look at their distributors link and it looks like those are all European companies as well.
11 Mar 2016 19:09 #71461
There must be sources closer to your half of the world than Rapid Electronics, but it might be worth pricing up an order and delivery just because you have already found them.
Time to create page: 0.148 seconds
