Need help with setup config. Cant get mill to home
24 Jun 2016 13:31 #76587 by MAG45
that chaged the error to 'swith inactive before.....'
24 Jun 2016 13:47 #76588 by Todd Zuercher
Replied by Todd Zuercher on topic Need help with setup config. Cant get mill to home
Ok, then change it back and now try the debounce.
I think this hal file should work.
File Name: mill-2.hal
File Size:4 KB
24 Jun 2016 15:04 #76597 by MAG45
1 step closer, thanks
With youe Hal file it homed Z (1st in sequence) but Z stayed sitting on the home switch then when X tried to home it just over ran past the switch. When I backe Z off the switch and tried to home only X it started searching in the wrong direction,
24 Jun 2016 16:20 #76602 by Todd Zuercher
If an axis is on the wrong side of a home switch, Linuxcnc has no way to know that, and will always search for home in the same direction. So the operator always mus make sure that the axis is on the right side before starting a home sequence.
First you need to make sure that each axis jogs in the correct directions (Z+ goes up, X+ to the right, and Y+ away from front, assuming a moving head and not a moving table).
If those are right then it is simply changing the signs of the home velocities to get them going the right way.
To get your Z (or any of the others) to move off the home switch, you may need to adjust the home offset and or home position. in the ini file.
The following user(s) said Thank You: MAG45
24 Jun 2016 21:47 #76628 by MAG45
Okay, i was thinking i was going to need to do that. Thanks for the hal file, I will work on the ini tomorrow and see if i can get her running.
25 Jun 2016 14:47 #76655 by MAG45
I got everything to home and moving the right directions. I tried to run a warmup program i still had on the thumbdrive and it wouldnt rue "exceeds limits" so i tried to edit it within Axis, but the editor wouldnt bring it up. Is there a known bug with the editor now, is there another program I can use to edit the .ngc?
25 Jun 2016 18:30 #76664 by BigJohnT
If your using Debian Sneezy then you need to install gedit or use the horrible mousepad...
In a terminal do the following to install gedit.
sudo apt-get update
sudo apt-get install -y gedit
sudo apt-get install -y gedit-plugins
JT
25 Jun 2016 20:52 #76666 by MAG45
sudo apt-get update
sudo apt-get iinstall -y gedit-plugins
JT
Thank you, that worked!
25 Jun 2016 23:26 #76668 by MAG45
And on to the next problem :-( the "controller" will just randomly power everything down. Like i pressed F2, Can be moving along and click, off' When this happens I have to switch off and on my E-stop/ main power for Axis to allow me to power on (F2) again.
27 Jun 2016 05:00 #76697 by cncbasher
Kate is another good editior , imho better than gedit
check for any auto off functions or hard drive shutdown
it may be motor noise being picked up on your inputs for example , or any leads longer than needed etc , or even a bad connector
Time to create page: 0.805 seconds
