How to. 2 or more motors on one axis. Gantry
5 years 10 months ago #193499 by rodw
[KINS] JOINTS = 4 KINEMATICS = trivkins coordinates=xyyz kinstype=b
is the last word meant to be both?
looks like a syntax error.
The following user(s) said Thank You: nau
5 years 10 months ago #193501 by nau
rodw wrote:
"man kins" says kinstype=b is correct setting. However I tried all tree ways:
1. kinstype=BOTH : same behaviour as with b and explained above. Also it is joints instead of axis in GUI.
2. kinstype=b :same as BOTH
3. skip kinstype : same behaviour as with b and BOTH but display axis correctly.
5 years 10 months ago #193512 by Clive S
nau wrote:
rodw wrote:
Have you confirmed that the sensor is working in with halshow
5 years 10 months ago #193520 by nau
Clive S wrote:
nau wrote: Have you confirmed that the sensor is working in with halshow
Yes. All sensor change states with halshow. And works perfectly with simply XYZ configuration.
5 years 10 months ago #193526 by rodw
Can you start Linuxcnc from the command line and paste the output to a text file and share it here?
That can offer uncover something
5 years 10 months ago #193557 by nau
rodw wrote: Can you start Linuxcnc from the command line and paste the output to a text file and share it here?
here is log with -v run from terminal.
From run Home all, home X&Z, stuck on Y hit e-stop after.
Time to create page: 0.227 seconds
