Homing speed for 2nd joint on single axis problem LinuxCNC 2.8
  • joel0407
  • joel0407's Avatar Topic Author
  • Premium Member
  • Premium Member
23 Sep 2017 09:10 #99311 by joel0407
Hey guys,
I can't get the second joint on my Y axis to home any faster than 1 machine-units per second.
I'll post the entire INI in the next post but basically I have:
HOME_SEQUENCE = -1
HOME_SEARCH_VEL = -1
HOME_LATCH_VEL = -1
HOME_FINAL_VEL = 1
HOME_USE_INDEX = NO
HOME_OFFSET = -10
for both joints on my Y axis. If I set any on the "VEL" settings to anything faster than 1, only Joint 1 (the first joint on the axis) moves at that speed and the second joint will still only move at 1.
I've tried setting HOME_SEQUENCE = -1 to -1 and -1 on both joints while leaving joints 0 and 3 at 0. Same but Y axis joints to 1 (non-negative), Same but one negative and the other not, all joints to 1 and all joints to -1.
  • joel0407
  • Premium Member
  • Premium Member
23 Sep 2017 09:10 #99312 by joel0407
[EMC]
MACHINE = my-mill
DEBUG = 0
VERSION = 1.0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 10.00
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 100.00
DEFAULT_ANGULAR_VELOCITY = 10.00
MIN_ANGULAR_VELOCITY = 0
MAX_ANGULAR_VELOCITY = 100.00
INTRO_TIME = 5
PROGRAM_PREFIX = /home/joel0407/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XYYZ
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 62500
SERVO_PERIOD = 1000000
[HAL]
HALFILE = my-mill.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
[TRAJ]
COORDINATES = X Y Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
MAX_LINEAR_VELOCITY = 200.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 200.0
MAX_ACCELERATION = 700.0
MIN_LIMIT = -0.001
MAX_LIMIT = 480.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 480.0
STEPGEN_MAXACCEL = 875.0
SCALE = 160.0
FERROR = 1
MIN_FERROR = .25
HOME_SEQUENCE = -1
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
[AXIS_Y]
MAX_VELOCITY = 95.0
MIN_LIMIT = -0.001
MAX_LIMIT = 695.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 695.0
MAX_VELOCITY = 95.0
SCALE = 160.0
FERROR = 1
MIN_FERROR = .25
HOME_SEQUENCE = -1
HOME_LATCH_VEL = -1
HOME_FINAL_VEL = 5
HOME_USE_INDEX = NO
HOME_OFFSET = -1
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 695
SCALE = 160.0
FERROR = 1
MIN_FERROR = .25
HOME_SEQUENCE = -1
HOME_SEARCH_VEL = -10
HOME_LATCH_VEL = -10
HOME_FINAL_VEL = 10
HOME_USE_INDEX = NO
HOME_OFFSET = -10
[AXIS_Z]
MAX_VELOCITY = 95.0
MIN_LIMIT = -110.0
MAX_LIMIT = 0.001
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -110.0
MAX_LIMIT = 0.001
MAX_VELOCITY = 95.0
SCALE = 160.0
FERROR = 1
MIN_FERROR = .25
HOME_SEQUENCE = -1
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
23 Sep 2017 11:19 - 23 Sep 2017 11:19 #99323 by rodw
From what I'm seeing is that your joint axis Y is on joints 1 and 2. You have different homing velocities on each side of the gantry... they should be identical ....
Last edit: 23 Sep 2017 11:19 by rodw.
  • joel0407
  • Premium Member
  • Premium Member
23 Sep 2017 11:43 #99324 by joel0407
I can't get Joint 2 to go faster than 1.
When I posted this INI. I was trying to increase joint 2 to see it move faster but it wont.
Even with them being identical. Joint 1 will move at whatever speed I set them both to but joint 2 will only move at 1.
23 Sep 2017 11:52 #99326 by rodw
You also have your z axis set with a homing sequence of -1 so that makes it part of the joint axis....
  • joel0407
  • Premium Member
  • Premium Member
23 Sep 2017 11:54 #99327 by joel0407
Yep, Tried 0 for X, -1 -1 for Y and 2 for Z
Tried -1 for X, -1 -1 for Y and -1 for Z
Tried 0 for X, 1 -1 for Y and 0 for Z
Tried 0 for X, -1 1 for Y and 0 for Z
Tried 0 for X, 1 1 for Y and 0 for Z
  • joel0407
  • Premium Member
  • Premium Member
23 Sep 2017 11:55 #99328 by joel0407
Just don't seem to be able to get the second joint to move faster. All works fine with manual homing. I'm cutting a part right now.
23 Sep 2017 12:26 #99331 by rodw
There is nothing wrong with the 2.8 homing sequence. I've been using it since day dot on my machine. There is something wong in your config or wiring.
  • joel0407
  • Premium Member
  • Premium Member
23 Sep 2017 13:06 #99333 by joel0407
Yep. I imagine you wouldn't be the only one.
Everything else is working fine and it homes fine (just at VEL 1) so I figure my wiring is fine.
Has to be my config but I can't find what.
23 Sep 2017 15:37 - 23 Sep 2017 15:39 #99342 by Clive S
I am not an expert but from what I see I think you have missed out the MAX_VELOCITY from join 2 I think it should be the same as Joint 1
Last edit: 23 Sep 2017 15:39 by Clive S.
The following user(s) said Thank You: joel0407
Time to create page: 0.298 seconds
