- Thank you received: 2181
technically MIN_LIMIT and MAX_LIMIT set the soft limits not the hard limits.MIN_LIMIT = 0 (hard limit min)
MAX_LIMIT = 440 (hard limit max)
I can do the full travel and it stops at the soft limit before it hits my end stop
it seams like setting the HOME_OFFSET = -3 is saying that the limit switch location is at -3 so it hits the switch homes to 1 then can never go below 0 because that is the hard limit negative of the machine
