Question on half step config
7 years 6 months ago #130122 by Todd Zuercher
If you currently have that pin connected to an output on your Linuxcnc computer and Linuxcnc is commanding that output. You probably only need to find that parallel port output pin in your hal file and comment it out (probably a setp line). I will be honest none of the machines I've worked with use that pin. If yours is using the whole step input it is most likely just a direct connection to 5v or ground and not wasting an output. I have the documents for the drives at work I just can't remember what they say whether the pin needs pulled high or low for full steps. But I know disconnected is half
7 years 6 months ago #130156 by Todd Zuercher
I looked up the manual today, "Logic 0" for full stepps is pin 8 pulled low (connected to ground). "Logic 1" is pin 8 high, 3.5-24v and it will float there if disconnected.
7 years 6 months ago #130160 by Mike_Eitel
I hate floating pins.
They always bite when you have no time for trouble. Fix it to either potential.
m5c
Mike
7 years 6 months ago #130162 by Todd Zuercher
Maybe I used bad terminology, the drive has an internal pull up, so the pin is either high or pulled low by something you've connected to it.
7 years 6 months ago #130165 by Mike_Eitel
Better felling ;-)
7 years 6 months ago #130502 by pl7i92
Replied by pl7i92 on topic Question on half step config
@125mike did this solve your problem as we like to here the GOOD news
Time to create page: 0.066 seconds
