Question on half step config
7 years 7 months ago #130016 by pl7i92
Replied by pl7i92 on topic Question on half step config
doesent half stepping Mean setting the DRIVER to 400 steps/rev
not the controll software
this is easy as it is DIP switch
7 years 7 months ago #130031 by allenwg2005
Todd,
This is an old DPF72004, as I recall you leave that wire disconnected for half step, I will check with them to confirm.
pl7i92,
This drive has an odd layout, dip switches for some things but not for the stepping, maybe because it's older.
Thanks again for the help.
7 years 7 months ago #130045 by Todd Zuercher
We still have a couple of machines running those old
drives at work.
7 years 7 months ago #130074 by pl7i92
Old Stuff is in Most Cases better then the Newer ones
so stay as long as you can with them
7 years 7 months ago #130103 by Todd Zuercher
I don't think that really applies to these. Newer bipolar drives can have better performance and are significantly cheaper to replace than these old uni-polar drives. I'll continue to repair the old ones if I can, but I doubt I'll ever buy another one.
7 years 7 months ago #130118 by allenwg2005
I email AA to determine what the proper way would be to half step with the drive I mentioned earlier; and if just disconnecting the terminal in question would be appropriate, here's a copy of the response:
"I was suggesting this for testing purposes, the best way to do this would be to designate that terminal as open through the controller. I would not know how you would do that with your controller however."
Any ideas on how to "designate" the terminal in LCNC?
Time to create page: 0.333 seconds
