Making a new non-simulated configuration
- Scot
- Thank you received: 6
03 Oct 2019 17:09 #146998
by Scot
Replied by Scot on topic Making a new non-simulated configuration
No problem, sir. The more I know, the better off I am. I'll be working on a lathe gui file for my configs and I'll let you know what happens. My DAC isn't functioning, so I have time to fiddle with the files to make a working interface for the time it takes to get a new DAC.
I love doing this stuff. So it's not an issue. Thanks for giving your insight, though. When I build a stepper system or a gecko type servo system, I'll be sure to use the paths you gave.
Scot
Scot
- Thank you received: 4652
04 Oct 2019 01:53 #147069
Replied by andypugh on topic Making a new non-simulated configuration
Thise page in the docs should guide you in what needs to be changed in your current config. (make a copy and work on that)
linuxcnc.org/docs/2.7/html/lathe/lathe-user.html
The following user(s) said Thank You: Scot
Time to create page: 0.082 seconds
