No Start on Linuxcnc 2.7.14 and 7i76e
6 years 11 months ago #149873 by +Jan+
Hello,
a friend of mine is currently setting up his CNC milling machine for his guitar workshop and I'm helping him with switch cabinet construction and software.
The switch cabinet is in operation so far and today it should go to the software.
He decided for the 7i76e and prepared his computer according to these instructions here:
Linuxcnc (2.7.14 on Debian Stretch) starts correctly with the simulation configurations.
After I created a configuration with pncconf for him today the big disillusionment came. Linuxcnc starts and crashes without error message (the logo appears and then nothing more).
When we start from the terminal the following message appears:
cnc@cnc:~$ sudo linuxcnc /home/cnc/linuxcnc/configs/iHSV57/iHSV57.ini [sudo] Passwort für cnc: LINUXCNC - 2.7.14-157-ga3f30ca35 Machine configuration directory is '/home/cnc/linuxcnc/configs/iHSV57' Machine configuration file is 'iHSV57.ini' Starting LinuxCNC... Found file(REL): ./iHSV57.hal Refusing to run as root without fallback UID specified To run under a debugger with I/O, use e.g., sudo env RTAPI_UID=`id -u` RTAPI_FIFO_PATH=$HOME/.rtapi_fifo gdb rtapi_app ./iHSV57.hal:3: waitpid failed /usr/bin/rtapi_app trivkins ./iHSV57.hal:3: /usr/bin/rtapi_app exited without becoming ready ./iHSV57.hal:3: insmod for trivkins failed, returned -1 Shutting down and cleaning up LinuxCNC... Running HAL shutdown script Refusing to run as root without fallback UID specified To run under a debugger with I/O, use e.g., sudo env RTAPI_UID=`id -u` RTAPI_FIFO_PATH=$HOME/.rtapi_fifo gdb rtapi_app LinuxCNC terminated with an error. You can find more information in the log: /root/linuxcnc_debug.txt and /root/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal
In the logs is also not that much information:
3327 Stopping realtime threads Unloading hal components
And
RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 INIFILE=/home/cnc/linuxcnc/configs/iHSV57/iHSV57.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=axis Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments
Also other sample configs like www.talla83.de/linuxcnc/iHSV57_2_7.zip cause the same behavior.
Any ideas to solve this problem?
Best wishes and thanks in advance
Jan
6 years 11 months ago #149876 by cmorley
why are you using sudo to run linxcnc?
This is not a good idea and is implied as the problem.
I don't know German so can't follow the video very well.
is this a compiled or installed version of linuxcnc?
Chris
6 years 11 months ago #149877 by +Jan+
Hey Chris,
it is a compiled version of Linux.
I can try without sudo tomorrow, but also if we start with the icon from the desktop the problem appears.
Best wishes
Jan
6 years 11 months ago #149878 by cmorley
trying on my installed version - I get the same error.
try starting without sudo
Chris
6 years 11 months ago #149879 by tommylight
It looks like you will have to install everything all over and this time skip the ROOT password, just click next.
Your Debian is installed and running as root user, and that is never good if you have no really good reason for it.
ASUS ROG Crosshair VIII Impact - AMD X570
6 years 11 months ago #149880 by cmorley
Did you run the command: sudo make setuid?
Time to create page: 0.092 seconds
