Homing procedure for axis with multiple slaves
- piter
6 years 7 months ago #160854
by piter
Replied by piter on topic Homing procedure for axis with multiple slaves
Ok, fixed all the side issues.
I've modified the ini file as follows:
[KINS] joints=4, kinematics = zzzz
[AXIS_Z]
[JOINT_0]
[JOINT_1]
[JOINT_2]
[JOINT_3]
and assigned the same homing procedure to all the joints.
Now, for the HAL file:
- each axis section starts with a list of setp (pid P, I, D, bias, FF0, ...): I'm looking at a sample configuration done with the pncconf wizard, where the only slave axis has pid.z2.PGain, .... -> how should it look like in my case?
[AXIS_Z]
[JOINT_0]
[JOINT_1]
[JOINT_2]
[JOINT_3]
- Clive S
- Thank you received: 486
6 years 7 months ago #160856
by Clive S
Replied by Clive S on topic Homing procedure for axis with multiple slaves
Posting your hal and ini files would help
- piter
6 years 7 months ago #160861
by piter
Think I solved it:
-> the naming should match with the function call "loadrt pid names=..." at the beginning of the file.
Now fighting with the HALUI signals ("halui pin ... does not exist")
I'll keep you updated
- piter
6 years 7 months ago #160863
by piter
HAL
INI
INI
- Clive S
6 years 7 months ago #160864
by Clive S
Yes you will have to duplicate the Z in the section of the hal file stuff and changing where necessary Z 0,1,2,3 etc
piter wrote: Think I solved it:
- Thank you received: 4153
6 years 7 months ago #160870
Easiest way to resolve this is to comment out the bad pin so Linuxcnc will load and then you can review in halshow to find the correct pin name.
Replied by rodw on topic Homing procedure for axis with multiple slaves
piter wrote: Now fighting with the HALUI signals ("halui pin ... does not exist")
Time to create page: 0.646 seconds
