Homing procedure for axis with multiple slaves
6 years 7 months ago #160875 by piter
Done! As rodw suggested, I removed all the halui related pins in the hal file, and everything loaded correctly.
I still get an error related to /usr/share/axis/images/axis.ngc, (X axis command, which does not exist here), but just acknowledge it.
As always, thank you all!
Pietro
6 years 7 months ago - 6 years 7 months ago #161346 by andypugh
Replied by andypugh on topic Homing procedure for axis with multiple slaves
If you don't have halui then it means that
[HAL]
HALUI = halui
is missing from the INI.
linuxcnc.org/docs/2.8/html/config/ini-config.html#_hal_section
Last edit: 6 years 7 months ago by andypugh.
Time to create page: 0.598 seconds
