Tandum Axis Shared Home/Limit Switches
6 years 5 months ago #167265 by Project_Hopeless
Tandum Axis Shared Home/Limit Switches was created by Project_Hopeless
I have a XYYZ gantry router setup. The X and Z axis are built and running, Homing etc. Next for me is setting up the tandem Y axis, dual motor, dual step drivers, home limit switches.
I'm using simple micro switches for the shared Home/limits.
Generally speaking what advice would you offer for mounting and setting up the switches on a tandem axis?
6 years 5 months ago #167267 by tommylight
Replied by tommylight on topic Tandum Axis Shared Home/Limit Switches
1 per side can do all the homing and limits if they are mounted on the gantry, otherwise one per side is usable for one side of the limit and home, not for both limits and home.
More info would help, like parallel or Mesa ?
For Mesa Pncconf will do almost all the stuff at once.
6 years 5 months ago #167309 by Project_Hopeless
Replied by Project_Hopeless on topic Tandum Axis Shared Home/Limit Switches
I'm running the MESA 7i96 and plan on 4 total limits for the tandem Y axis.
I guess what I'm wondering is how to physically setup the Home/Limits so when homing the gantry doesn't rack to much. Can you physically sync the two pair of home switches? Is it necessary?
6 years 5 months ago #167340 by Clive S
Replied by Clive S on topic Tandum Axis Shared Home/Limit Switches
Project_Hopeless wrote: I'm running the MESA 7i96 and plan on 4 total limits for the tandem Y axis.
When homing two tandem motors they home in sync with each other at the same time, this is achieved by making sure the the sequence No. in the ini file has a -ve sign before the sequence No.
6 years 5 months ago #167457 by cmorley
Replied by cmorley on topic Tandum Axis Shared Home/Limit Switches
i was thinking he means the _physical_ limit switches.
I bet he is wondering how important that the two switches be aligned to each other to stop racking.
IIRC linuxcnc moves both axis until one switch is tripped then that axis stops and the other continues till that ones stops, then they move together.
I don't see any description in the docs that thoroughly describe tandem homing.
Can anyone confirm what actually happens - for instance are back off a retrip moves done together or separately?
Chris
6 years 5 months ago #167483 by tommylight
cmorley wrote: IIRC linuxcnc moves both axis until one switch is tripped then that axis stops and the other continues till that ones stops, then they move together.
That is correct when set properly.
Time to create page: 7.971 seconds
