Tandum Axis Shared Home/Limit Switches
  • Project_Hopeless
  • Project_Hopeless's Avatar Topic Author
  • Elite Member
  • Elite Member
10 May 2020 14:10 #167265 by Project_Hopeless
Tandum Axis Shared Home/Limit Switches was created by Project_Hopeless
I have a XYYZ gantry router setup. The X and Z axis are built and running, Homing etc. Next for me is setting up the tandem Y axis, dual motor, dual step drivers, home limit switches.
I'm using simple micro switches for the shared Home/limits.
Generally speaking what advice would you offer for mounting and setting up the switches on a tandem axis?
  • Moderator
  • Moderator
10 May 2020 14:25 #167267 by tommylight
Replied by tommylight on topic Tandum Axis Shared Home/Limit Switches
1 per side can do all the homing and limits if they are mounted on the gantry, otherwise one per side is usable for one side of the limit and home, not for both limits and home.
More info would help, like parallel or Mesa ?
For Mesa Pncconf will do almost all the stuff at once.
  • Project_Hopeless
  • Elite Member
  • Elite Member
10 May 2020 22:43 #167309 by Project_Hopeless
Replied by Project_Hopeless on topic Tandum Axis Shared Home/Limit Switches
I'm running the MESA 7i96 and plan on 4 total limits for the tandem Y axis.
I guess what I'm wondering is how to physically setup the Home/Limits so when homing the gantry doesn't rack to much. Can you physically sync the two pair of home switches? Is it necessary?
11 May 2020 07:55 #167340 by Clive S
Replied by Clive S on topic Tandum Axis Shared Home/Limit Switches
When homing two tandem motors they home in sync with each other at the same time, this is achieved by making sure the the sequence No. in the ini file has a -ve sign before the sequence No.
12 May 2020 04:05 #167457 by cmorley
Replied by cmorley on topic Tandum Axis Shared Home/Limit Switches
i was thinking he means the _physical_ limit switches.
I bet he is wondering how important that the two switches be aligned to each other to stop racking.
IIRC linuxcnc moves both axis until one switch is tripped then that axis stops and the other continues till that ones stops, then they move together.
I don't see any description in the docs that thoroughly describe tandem homing.
Can anyone confirm what actually happens - for instance are back off a retrip moves done together or separately?
Chris
  • Moderator
  • Moderator
12 May 2020 08:07 #167483 by tommylight
That is correct when set properly.
20 May 2020 03:06 #168340 by keyboard
Replied by keyboard on topic Tandum Axis Shared Home/Limit Switches
Ok, after setting my home switches to switch on at the same time as close as possible, can I use the HOME_OFFSET = with a different value to correct racking or squareness to the X axis. ? for both joints. ?
In other words for example:
Joint 1
HOME_OFFSET = 3.000
Joint 3
HOME_OFFSET = 3.054
20 May 2020 04:10 #168341 by cmorley
That seems reasonable - easy to test.
If that works that means the final home move is when the synchronizing is complete.
20 May 2020 05:14 #168343 by rodw
Replied by rodw on topic Tandum Axis Shared Home/Limit Switches
Joint 1
HOME_OFFSET = 3.000
Joint 3
HOME_OFFSET = 3.054
Thats exactly what to do if your measurements are precise.
I did read a machine setup manual the other day that suggested you mark the corners of the largest square you can fit on your machine, measure the diagonals and do some maths to calculate the error. I was going to do it to mine one day..
21 May 2020 02:39 #168460 by cmorley
can you confirm the complete homing sequence including latching for tandem axes?
ie after initial tripping of the switch of both joints, does it search the final trip point of both joints together, does each joint stop when the trip point is found etc.
Thinking about docs
Time to create page: 0.185 seconds
