- Thank you received: 4
keyboard wrote: Ok, after setting my home switches to switch on at the same time as close as possible, can I use the HOME_OFFSET = with a different value to correct racking or squareness to the X axis. ? for both joints. ?
In other words for example:
Joint 1
HOME_OFFSET = 3.000
Joint 3
HOME_OFFSET = 3.054
