- Configuring LinuxCNC
- Basic Configuration
- Full Revolution issues - Rotary Axis - Barrel Organ Machine
- Thank you received: 7468
04 Jun 2020 09:54 #170090
Replied by tommylight on topic Full Revolution issues - Rotary Axis - Barrel Organ Machine
This might be useful
- pijki
04 Jun 2020 16:29 #170102
by pijki
Replied by pijki on topic Full Revolution issues - Rotary Axis - Barrel Organ Machine
Yes, in fact, It was an hardware issue. I have removed the motor and, it was doing the full revolution in both direction acuratly. So I worked today on a stronger fixation for the motor, with iron this time...
Thanks a lot, I was not seeing the issue, and since im a newbie, I was thinking it was a software issue.
Cheers !
Cheers !
- Thank you received: 2164
05 Jun 2020 05:17 #170198
Replied by Aciera on topic Full Revolution issues - Rotary Axis - Barrel Organ Machine
I'm glad you figured it out. Thanks for reporting back.
- bbsr_5a
- Thank you received: 106
05 Jun 2020 06:22 #170203
by bbsr_5a
Replied by bbsr_5a on topic Full Revolution issues - Rotary Axis - Barrel Organ Machine
if it is posible can you specifie the fixure problem Off Axis mount or different Direct mount
Time to create page: 0.094 seconds
