ASD-A2 EtherCAT on LinuxCNC
6 years 4 months ago #172212 by PCW
Replied by PCW on topic ASD-A2 EtherCAT on LinuxCNC
The velocity scaling would have no relation to voltage, I would expect the default
scaling is in RPM or RPS, but that is just a guess. Doesn't the drive manual specify the velocity scaling?
6 years 4 months ago - 6 years 4 months ago #172224 by jirkam
Replied by jirkam on topic ASD-A2 EtherCAT on LinuxCNC
I'm not sure I know what information to look for.
I'm looking for it here:
When you have a moment, please take a look at it?
Very Thanks
Last edit: 6 years 4 months ago by jirkam.
6 years 4 months ago #172241 by PCW
Velocity is specified in units of 0.1 RPM ( operation manual page 6-15 )
6 years 4 months ago #172250 by jirkam
Thank you for the info.
I found something similar on page 5-8 but I didn't know how to use this value in the calculation.
I probably won't delay you anymore and I'll try to tune it again tomorrow. :)
I'll write if I succeeded.
Thank you so much for your time.
Jirka
6 years 4 months ago #172304 by jirkam
Obviously I'm doing something wrong or I didn't understand the tuning process.
FERROR = 100
MIN_FERROR = 100
P = 5
DEADBAND = 0.0001
MAX_OUTPUT = 230
The rest = 0
I set FF1 to 0.1; 0.2; 0.3; 0.5; 0.8; 1.0; 10; 20; 30; 50; 100; 150 and no change to the "joint.0.f-error" curve.
Each time I click on the cursor left or right (do not hold), the "joint.0.f-error" changes by about 2mm and returns to zero for 30 seconds.
Ends with "joint.0.f-error" = 0.42mm.
Can you please advise me what he's doing wrong?
Thank you very much.
6 years 4 months ago #172497 by chimeno
Replied by chimeno on topic ASD-A2 EtherCAT on LinuxCNC
Hi @Jirkam
I work in speed mode with ethercat servo drive,
It depends on how you have configured the speed mode in the drive., in the DELTA manual I see that for a 3000 rpm motor you need to enter a command of 30,000, then you would have to try
setp lcec.0.x.srv-velo-cmd 30000
maximum engine speed for checking
setp lcec.0.x.srv-velo-cmd 15000
average engine speed for checking
Now let's configure the PID
P = 1
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
DEBAND = 0
MAX_OUTPUT 30000
Now it has to work
Now adjust P until it starts to vibrate and lower it a little, my house is around 200
then surely you lack acceleration
configure the parameters
P1-34
P1-35
I hope I helped you
Cheers
Chimeno
Time to create page: 0.540 seconds
