ASD-A2 EtherCAT on LinuxCNC
5 years 1 month ago #219789 by jirkam
Replied by jirkam on topic ASD-A2 EtherCAT on LinuxCNC
Hello.
So I'm back.
It lasted without a mistake for a few weeks. I managed to record the behavior on video.
Here is the video
1.red - joint.0.f-error ("X" axis)
2.blue - joint.1.f-error ("Y" axis)
3.green - joint.2.f-error ("Y" axis)
4.purple - joint.3.f-error ("Z" axis)
5.orange - lcec.0.pll-out
6.green - lcec.0.pll-err (it is marked on the video - therefore it is white)
Sometimes he doesn't do it all week.
Sometimes he does it twice a day.
Sometimes he does it all day.
Sometimes it stops making mistakes on its own.
Sometimes I have to restart Linuxcnc to stop making mistakes.
Does anyone know where the problem might be?
Thank you very much Jirka
3 years 10 months ago #258559 by mehdidadash
Hi jirkam
Can you attach your final configuration files like XML, INI, HAL,... ?
3 years 10 months ago #258589 by jirkam
Hi
I found out that if I turn on the drivers first and only the PC after about 10 seconds, then it doesn't make the error.
Thank you.
Jirka
The following user(s) said Thank You: mehdidadash
3 years 10 months ago #258592 by db1981
Replied by db1981 on topic ASD-A2 EtherCAT on LinuxCNC
Hello Jirka,
i have noticed an "~big" error in your hal file.
you adding lcec.real-all and write-all at the beginning of the hal file.
caused that liunxcnc builds its execution order of task functions in the order they are placed in the hal file, your servo-thread calls ec-read and then immediatly writes out lcec-write. So nothing is done with the Data in the meantime. Lcec.write-all uses "old"data from the last cycle . Which causes timing issues and leads to an bad servo tuning.
the right order would be:
addf lcec.read-all (gets data from hardware)
addf motion, value-converts, pids, classicladder etc.. (works with the data)
last addf lcec.write-all (send new data to hardware).
In your case lcec.write-all is called in front of motion and pids. So it sends "old" data from the last cylce to the drives without the new calculations. You got an 1
cycle offset between input and output data.
(you can search for "execution order" in the forum, i have descripted this in detail somewhere)
3 years 10 months ago #258627 by jirkam
Hello "db1981"
Thank you very much for the tip.
When I write it like this:
# Generated by stepconf 1.1 at Thu Sep 10 02:41:11 2020 # If you make changes to this file, they will be # overwritten when you run stepconf again loadrt [KINS]KINEMATICS loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_dio=24 num_aio=8 loadrt pwmgen output_type=1 loadusr ethercat debug 1 loadusr -W lcec_conf delta_pos.xml loadrt lcec addf lcec.read-all              servo-thread loadusr ethercat debug 0 addf pwmgen.make-pulses base-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf pwmgen.update servo-thread addf lcec.write-all             servo-thread
so will it be ok?
Will the servos behave completely differently, or will the behavior change slightly?
Thank you very much.
Jirkam
3 years 10 months ago #258634 by db1981
that is the correct order.
you are not using pids in linuxcnc. So the behavior will change slightly.
Time to create page: 0.549 seconds
