Deactivate or increase the soft limit
- cyberspaceschwabe
22 Aug 2020 11:47 #178989
by cyberspaceschwabe
Deactivate or increase the soft limit was created by cyberspaceschwabe
Hello my name is Stefan Mangold
I registered again here because I have several problems with Linux-CNC.
Use LinuxCNC for a while and face a problem. I built a fourth axis and I want it to run endlessly like a lathe. But don't get the soft limit deactivated or increased.
Soft limit only goes from min / max 99999.
I'm currently using the Axis Screen.
Who can help me please.
Stefan
Stefan
- Thank you received: 7468
22 Aug 2020 12:26 #178990
- cyberspaceschwabe
22 Aug 2020 14:26 #178999
Replied by cyberspaceschwabe on topic Deactivate or increase the soft limit
You misunderstood me. I am satisfied with the function of the fourth axis.
Since Axis-Screen has a limit of min / max 99999
That would like to deactivate the limit
- MaHa
- Thank you received: 240
22 Aug 2020 15:17 #179002
by MaHa
Replied by MaHa on topic Deactivate or increase the soft limit
I did comment the limitation in ini file, [AXIS_3], and the A-axis can spin for days.
# MIN_LIMIT = -99999.0
# MAX_LIMIT = 99999.0
- cyberspaceschwabe
22 Aug 2020 16:08 #179008
Solved my problem
I had the limit in two places
Once in [AXIS A]
and once in [Joint_3]
But only commented in [AXIS A] and not in [Joint_3]
Thanks again
Once in [AXIS A]
Thanks again
22 Aug 2020 20:42 #179030
Replied by tommylight on topic Deactivate or increase the soft limit
Sorry about that.You misunderstood me. I am satisfied with the function of the fourth axis.
