LinuxCNC trips on M6
  • underscore
  • underscore's Avatar Topic Author
  • Junior Member
  • Junior Member
01 Sep 2020 02:35 #180250 by underscore
LinuxCNC trips on M6 was created by underscore
I've been trying to get manual tool changes to work with linuxcnc, but every time I execute a M6 it switches to the "e-stop tripped" state. If I set a tool change position, it first moves to that position and then trips. That position is definitely within the soft limits. hal_manualtoolchange is configured following the man page.
Could someone point me in the right direction how to debug that problem? DEBUG=0x7FFFFFFF didn't produce anything suspicious looking. One non-standard configuration of my system is that I use XYZACW, maybe related (i.e. soft limits for unused axes)?
P.S.: I'm running the latest version from GitHub.
  • Moderator
  • Moderator
01 Sep 2020 10:16 #180295 by tommylight
Replied by tommylight on topic LinuxCNC trips on M6
Are you using a spindle with a VFD?
  • underscore
  • Junior Member
  • Junior Member
01 Sep 2020 11:45 #180314 by underscore
Replied by underscore on topic LinuxCNC trips on M6
No, at this point I’m manually controlling the spindle (I.e. outside of linuxcnc).
  • Moderator
  • Moderator
01 Sep 2020 11:50 #180315 by tommylight
Can you please attach the hal and ini files here ?
  • underscore
  • Junior Member
  • Junior Member
01 Sep 2020 13:03 #180327 by underscore
Thanks for your assistance. I uploaded all my files, but only the *.ini, taig_mill.hal, tool change.hal and halui.hal should be relevant.
It's my first time using linuxcnc, so please excuse if it is a little messy!
File Name: buttons_20...9-01.hal
File Size:2 KB
File Name: pendant_20...9-01.hal
File Size:9 KB
File Name: serialhal_...9-01.hal
File Size:0 KB
File Name: halui_2020-09-01.hal
File Size:4 KB
File Name: toolchange...9-01.hal
File Size:0 KB
File Name: taig_mill_...9-01.ini
File Size:8 KB
File Name: taig_mill_...9-01.hal
File Size:19 KB
  • underscore
  • Junior Member
  • Junior Member
02 Sep 2020 02:43 #180385 by underscore
Here is the output when running with DEBUG=0x7FFFFFFF. The Tnn and M6 are fairly far down.
I noticed the following line:
emcTaskPlanExecute(M6) returned 2
(In addition I tried some basic remapped M6 and a similar thing happens, except I cannot get out of the e-stop state anymore without restarting. Very odd. The code inside my remapped *.ngc is executed, at least to the point where I'm waiting on a digital input, but emc is already in the e-stop stage...)
File Name: log.txt
File Size:15 KB
  • underscore
  • Junior Member
  • Junior Member
03 Sep 2020 02:00 #180480 by underscore
Ok, quick update:
When I use an external e-stop, e-stop trips on M6:
net estop-out => hm2_5i25.0.7i76.0.0.output-07
net estop-in <= hm2_5i25.0.7i76.0.0.input-07
net estop-in => iocontrol.0.emc-enable-in
If I bypass that and just loopback the signals from iocontrol it works!
net estop-loop <= iocontrol.0.user-enable-out => iocontrol.0.emc-enable-in
What is going on here?! Some time(out) issue?
  • underscore
  • Junior Member
  • Junior Member
06 Sep 2020 16:38 #181035 by underscore
Mystery solved, the estop output and the tool change indicator led wires were physically swapped... such an odd problem. Anyway, works like a charm now!
