Prevent spindle start if a certain tool is selected?
  • JetForMe
  • JetForMe's Avatar Topic Author
  • Elite Member
  • Elite Member
24 Oct 2020 04:46 #187065 by JetForMe
Is there any way to prevent the spindle from starting (via any possible mechanism like M3/M4 or clicking spindle start buttons in the UI) if a particular tool is selected (e.g. my Haimer probe)?
24 Oct 2020 04:54 #187066 by Henk
If the probe is wired with the contact in a normally closed mode, you can use the probe signal to interlock the spindle enable.
This way, when the probe is plugged in, the spindle cannot start.
24 Oct 2020 05:55 #187068 by cmorley
there is even a HAL pin for it:
spindle.N.inhibit - (bit, in) When this bit is TRUE, the spindle speed is set to 0.
  • The Feral Engineer
  • The Feral Engineer's Avatar
  • Senior Member
  • Senior Member
16 Dec 2020 19:32 - 16 Dec 2020 19:33 #192162 by The Feral Engineer
Replied by The Feral Engineer on topic Prevent spindle start if a certain tool is selected?
i'm actually trying to use spindle.0.inhibit right now in classicladder and the spindle is still coming on even with it set to true. I'm using a sim, though, so i'm not sure if that makes a difference.
Last edit: 16 Dec 2020 19:33 by The Feral Engineer.
  • Senior Member
  • Senior Member
16 Dec 2020 19:38 #192164 by The Feral Engineer
okay, i see it now. when i use halconfig to check out my spindle.0.on, with the inhibit circuit, it doesn't turn on.
16 Dec 2020 19:51 - 16 Dec 2020 20:19 #192171 by alkabal
Hi
I actually facing the same things i like to make spindle impossible to rotate if touch probe NPN NC is dected as connected, i have also think about using toolnumber or using both.
For now i dislike the spindle.N.inhibit because they work like a pause so spindle M3 M4 are not canceled.
Beter imo to cancel operation than only lock.
I Have for now do nothing for this but i use a similar scenario from my toolchanger using this signal but i did not remenber if this stop only gcode execution or also the spindle.
net tool-program-abort toolchanger.program-abort => halui.abort
Last edit: 16 Dec 2020 20:19 by alkabal.
  • Moderator
  • Moderator
16 Dec 2020 20:22 #192177 by tommylight
I do not think the clasicladder is the way of doing this, hal is better in my opinion.
Spindle has another pin that should be possible to use
spindle-on
and
motion.spindle-on
Pulling that down should disable spindle.
16 Dec 2020 20:26 - 16 Dec 2020 20:42 #192180 by alkabal
Well i think about using a logic like this
if Probe.input = 1 and (spindle.0.on or spindle.0.orient or Tool =1)
Then toggle halui.abort and display warning to user
Last edit: 16 Dec 2020 20:42 by alkabal.
16 Dec 2020 20:28 - 16 Dec 2020 20:30 #192182 by alkabal
spindle-on
and
motion.spindle-on
Well i think this is a possible dangerous way to do this using only bypass for spindle-on because if you now remove the probe the spindle start directly
motion.spindle-on is imo not the best option, for me the best is use halui.abort : machine stay on and ready for next things vs machine is like closed. (and if you try to send message to user after motion.spindle-on altering to 0 this not possible.
Last edit: 16 Dec 2020 20:30 by alkabal.
  • Moderator
  • Moderator
16 Dec 2020 20:41 #192186 by tommylight
I have to agree, that does not sound good.
Time to create page: 0.126 seconds
