How to build a spaceship with Linuxcnc and a Mesa 7i76e
5 years 8 months ago #197381 by rodw
I've had in mind to do this for a long time. But here is a tutorial about how to start with a Mesa 7i76e
It covers all the basics:
Power connection,
Mesa IP address config
Connecting inputs - mechanical and proximity sensors
Connecting relays and triggering them with M3/M4 and M64/M65
There is still more to come.... but I thought 50 minutes was long enough. :)
But if you are just starting out, it will be the best 50 minutes you'll ever spend!
The following user(s) said Thank You: tommylight, johnmc1, JohnnyCNC, Noxaw, Lethal69GTO, Utilitas
5 years 8 months ago #197399 by tommylight
5 years 8 months ago #197607 by kramerda
Very nice Rod - thankyou
Can you include a reference/URL to the (Norbert ?) connection diagram you mentioned?
5 years 8 months ago #197616 by rodw
just google it or search on this forum for "my 7i76e connection sheet"
5 years 8 months ago #197820 by newbynobi
5 years 5 months ago #208978 by Lethal69GTO
Fantastic introduction!
I have been foundering a bit as I have no experience with any of this electronics stuff and your video has provided some key fundamental insight. A question or two if I may... I think I understand that I can signal the turning on/off of 110V peripheral device such as a shop-vac using one of those electromagnetic power relays, correct? Question is, what size/type fly-back diode to be used? Are they sized for particular load (amps?).
Much appreciated.
Darryl
Time to create page: 0.361 seconds
