How to build a spaceship with Linuxcnc and a Mesa 7i76e
11 Dec 2024 13:14 #316468 by Wrightys99
timo
Thank you :)
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
12 Dec 2024 04:02 #316495 by rodw
I don't think there is a way to write from LInuxcnc to the MPG Screen. I think it must use the USB for that.
As far as the wiring goes, the circuit diagram on the receiver is all you need as each part is a seperate set of pins.
The estop is designed to be standards based with two redundant circuits but it works for a single sided estop as well.
You used to have to ask for a 5 volt encoder for mesa but now I think there is a switch to select between 5v and 24v on the board.
I always have used the digital I/O for axis and jog speed select to save pins (with a MUX8 or MUX4)
This recent config I did uses the same pendant and there is a seperate hal file and also a custom component to manage the three jogging buttons
github.com/rodw-au/showstopper
23 Dec 2024 23:09 #317241 by Dave2024
I bet you just sold allot of Mesa 7i76e's with this video!  Cool, thanks
  • rodw
  • Platinum Member
  • Platinum Member
23 Dec 2024 23:11 #317242 by rodw
Nah, but perhaps PCW did!
Time to create page: 0.188 seconds
