How to build a spaceship with Linuxcnc and a Mesa 7i76e
- Thank you received: 4149
02 Feb 2021 06:40 #197381
How to build a spaceship with Linuxcnc and a Mesa 7i76e was created by rodw
I've had in mind to do this for a long time. But here is a tutorial about how to start with a Mesa 7i76e
It covers all the basics:
Power connection,
Mesa IP address config
Connecting inputs - mechanical and proximity sensors
Connecting relays and triggering them with M3/M4 and M64/M65
There is still more to come.... but I thought 50 minutes was long enough.
But if you are just starting out, it will be the best 50 minutes you'll ever spend!
Power connection,
The following user(s) said Thank You: tommylight, johnmc1, JohnnyCNC, Noxaw, Lethal69GTO, Utilitas
- Thank you received: 7478
02 Feb 2021 10:04 #197399
Replied by tommylight on topic How to build a spaceship with Linuxcnc and a Mesa 7i76e
Very nice, thank you.
- kramerda
- Thank you received: 14
03 Feb 2021 23:39 #197607
by kramerda
Replied by kramerda on topic How to build a spaceship with Linuxcnc and a Mesa 7i76e
Very nice Rod - thankyou
Can you include a reference/URL to the (Norbert ?) connection diagram you mentioned?
04 Feb 2021 02:52 #197616
Replied by rodw on topic How to build a spaceship with Linuxcnc and a Mesa 7i76e
just google it or search on this forum for "my 7i76e connection sheet"
- newbynobi
- Thank you received: 394
06 Feb 2021 10:32 #197820
by newbynobi
Replied by newbynobi on topic How to build a spaceship with Linuxcnc and a Mesa 7i76e
it's
here
- Lethal69GTO
15 May 2021 21:01 #208978
by Lethal69GTO
Replied by Lethal69GTO on topic How to build a spaceship with Linuxcnc and a Mesa 7i76e
Fantastic introduction!
I have been foundering a bit as I have no experience with any of this electronics stuff and your video has provided some key fundamental insight. A question or two if I may... I think I understand that I can signal the turning on/off of 110V peripheral device such as a shop-vac using one of those electromagnetic power relays, correct? Question is, what size/type fly-back diode to be used? Are they sized for particular load (amps?).
Much appreciated.
Darryl
Much appreciated.
Darryl
15 May 2021 23:28 #209005
An IN4007 is all you need. The IN400X series basically just have different voltage ratings so 1000V should be enough!
- Wrightys99
14 Nov 2024 12:51 #314441
by Wrightys99
Replied by Wrightys99 on topic How to build a spaceship with Linuxcnc and a Mesa 7i76e
Rodw
Thank you just what I needed.
I appreciate your time in creating this.
Cheers
Cheers
- Wrightys99
10 Dec 2024 13:54 #316407
by Wrightys99
Hi Rodw
I purchased the MPG pendant i think it might be the same as yours, although this has the screen.
www.aliexpress.com/item/1005002095130699...n.498.21ef1802xJ8JwX
I have been trying to find the post in the forum in which you discussed this so that i may add to it.
I purchased a 7i96s with a 7173 and a 7i95T. I will porobably go with the 7i95T as it has lots of I/O for future expansion on my CNC and some planned projects i would like to add to my CNC.
Im still new to CNC although i have been involved with 3D printing since its inception, which gives me some transferrable skills. Im an electrical engineer by trade so although a steep learning curve, im sure i will succeed in my venture.
The reason for my message is the pendant i bought i chose as it has the STWGP interface for connecting to my 7i95T.
Would you have a wiring diagram you used for your connections between your 7i76E and the STWGP.
Im just striking up a conversation with the manufacturer of the pendant and he has asked for a wiring diagram to check its suitablility.
I was hoping if you dont mind to use your connections as a base for my wiring scheme.
Anything further you can add or setup files would be greatly appreaciated, or if in the linuxcnc domain a link if you wouldnt mind.
Kindest regards
Andy
Kindest regards
Andy
- timo
- Thank you received: 61
11 Dec 2024 06:05 - 11 Dec 2024 06:07 #316452
by timo
Replied by timo on topic How to build a spaceship with Linuxcnc and a Mesa 7i76e
Did you have a look at this?
linuxcnc.org/docs/html/examples/mpg.html
This gave me the basic idea, and then I could change the *.hal according to the requirements.
To me it looks that this wireless thing just connects to the machine like a normal wired device.
I am not using an "official encoder input" for the MPG just normal inputs were doing the job, So I did not change the bitfile on Mesa card plug and go kit.
Last edit: 11 Dec 2024 06:07 by timo.
Time to create page: 0.726 seconds
