Proximity sensor question
15 Mar 2021 01:01 #202285 by motal2004
Proximity sensor question was created by motal2004
Quick question peeps
I have PNP NO proximity sensors that I am putting on my new 4’x4’ Cnc plasma build. How are these wired to Mesa 7i96 my old build I had NPN.
Thanks for the help
15 Mar 2021 01:16 #202287 by Michael
Replied by Michael on topic Proximity sensor question
How do you have the input of your 7i96 setup? What is wired to your TB3 Pin 12?
Ideally you want this pin grounded to your 24v power source (assuming thats what you are using). The common pin out on proximity sensors is Brown+, Blue- and Black is signal. The black should go high when tripped so it needs to plug into TB3 Input Pin 1-11.
15 Mar 2021 02:14 #202294 by motal2004
Replied by motal2004 on topic Proximity sensor question
V+ out of meanwell ps is going to common pin TB3 12
Blue -> common on power supply
Brown -> v+ Power supply
Black -> tb3 input 1
15 Mar 2021 02:51 - 15 Mar 2021 15:32 #202299 by Michael
Thats not going to work. Are you dead set on sourcing input? That is running V+ to TB3 12? the best practice for PNP NO will be to have V- to TB3 12 and wired as you just described.
Last edit: 15 Mar 2021 15:32 by Michael.
15 Mar 2021 08:39 #202318 by Clive S
Replied by Clive S on topic Proximity sensor question
Re:
and
Michael wrote .Thats not going to work. Are you dead set on sourcing input? That is running V+ to TB3 12? the best practice for PNP NC
PNP NO verses PNP NC just pointing out for the benefit of others is the PNP NC a typo ?
15 Mar 2021 13:23 #202348 by motal2004
No , not dead set , just want to make it work. What’s your recommendation again ?
15 Mar 2021 15:42 - 15 Mar 2021 15:43 #202363 by Michael
Yes that was a typo up there, it's fixed.
This should be how you wire them:
V- out of meanwell ps is going to common pin TB3 12
This will cause the input to be on when the sensor is triggered. And if they are not triggered or the wire shorts then they do not activate. That is why it's preferred to use PNP NO sensors. They won't show active if they short out. Technically the 7i96 can run either but all of the inputs have to be the same way.
If you plan on running any other input into the 7i96 and have it wired the way I just mentioned then it would need to follow this simple switch example.
+V of ps => switch+ => switch- => 7i96 input pin
Last edit: 15 Mar 2021 15:43 by Michael.
15 Mar 2021 16:24 #202368 by motal2004
is there away to wire proximity senors to use the mesa 7i96 own output power, to avoid having to used an additional power supply?
16 Mar 2021 02:25 #202439 by Michael
Yes that shouldn't be a problem as long as the sensors run on 5v
16 Mar 2021 04:19 #202445 by motal2004
How would one go about that way, I do have 5v proximity sensors. Thanks again for the help
Time to create page: 0.202 seconds
