Please help me get this Homing Sequence Right
  • Moderator
  • Moderator
15 May 2021 17:05 #208931 by tommylight
Replied by tommylight on topic Please help me get this Homing Sequence Right
Sorry Bev, fixed above.
15 May 2021 17:36 #208935 by bevins
To be even more clear the positive and negative limit switches on each axis are connected to the same physical input for that axis.
So even though there are 8 limit switches ( 2 each on axis XYZ) and 1 for each rotary axis they are only using a total of 5 inputs on the Mesa Card.
Why would you do that? you have the switches, they should be one input for each. There should be plenty on mesa board. I didnt check which one you had but, drop the neg limit then.
Did you get it working?
15 May 2021 17:51 #208940 by eighthaxis
Replied by eighthaxis on topic Please help me get this Homing Sequence Right
No just even more confused
15 May 2021 18:10 #208945 by eighthaxis
I did what you said Tommy
net y-home-sw <= hm2_5i25.0.7i77.0.0.input-01
net both-y <= hm2_5i25.0.7i77.0.0.input-01
All that should be
net both-home-y <= hm2_5i25.0.7i77.0.0.input-01
now here is my newest error and files.:
Debug file information:
Note: Using POSIX realtime
./Bostomatic.hal:120: Pin 'hm2_5i25.0.7i77.0.0.input-00' was already linked to signal 'both-x'
1478
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7fea57c9e000
15 May 2021 20:18 - 15 May 2021 20:23 #208966 by Michael
Replied by Michael on topic Please help me get this Homing Sequence Right
I think we need to slow down a second. The best analogy for what your missing is that your wires (hal wording) are not connecting to the correct things. Look at this example:
# --- BOTH-X ---
net both-x <= hm2_5i25.0.7i77.0.0.input-00
This would work functionally the same as:
net i-like-turtles <= hm2_5i25.0.7i77.0.0.input-00
The words after net are just a naming convention and anything can be used for that particular "wire". The parts after the i-like-turtles is what wires connect to. Right now you just have a loose wire with one side connected.
A better way to right connections that visually make sense is:
net both-x hm2_5i25.0.7i77.0.0.input-00 =>
joint.0.home-sw-in
This says that the wire called both-x connects the 7i77 in 00 to the motion control pin for x axis home switch. The below says the same exact thing but written a different way:
net both-x joint.0.home-sw-in
Does this make sense? Your physical pins need to be connected to motion control of Linuxcnc.
linuxcnc.org/docs/2.8/html/man/man9/motion.9.html#JOINT%20PINS
You also have this:
net both-home-x <= hm2_5i25.0.7i77.0.0.input-00
which means you have two instances of loose wires for the same input
Last edit: 15 May 2021 20:23 by Michael.
  • Moderator
  • Moderator
15 May 2021 20:26 #208969 by tommylight
All that should be
This has to be done for all the joints/axis that use a single switch for home and both limits.
Check Michael's post to get an idea how things function.
15 May 2021 20:33 #208970 by Michael
So the above was just for a single x axis home switch. If you want the same pin to be used as a limit switch then you will need to connect the following:
joint.N.neg-lim-sw-in
and
joint.N.pos-lim-sw-in
Something like the following should make the same input function for negative limits, positive limits and homing switch also:
net both-x joint.0.neg-lim-sw-in
net both-x joint.0.pos-lim-sw-in
I am doing this from my phone and can't view some of the items I normally would but this should work.
The following user(s) said Thank You: eighthaxis
15 May 2021 21:12 #208981 by eighthaxis
Thank you for the continual input. I will give it a try and get back to you.
15 May 2021 23:17 #209002 by eighthaxis
Hurray I have had some success thanks to your Help!
It will now Autohome XYZ successfully after adding your HAL entries and modifying the ini file a few times.
A and B are not homing correctly.
I keep getting joint following errors.
I can JOG B around with no joint following errors (although the scaling is wrong) but when homing it moves to the switch backs off about 25 degrees then give the joint following error
A-axis I can't jog at all because I can't figure out how to get the A jog buttons to appear in GMOCCAPY: forum.linuxcnc.org/gmoccapy/39723-edit-j...tons?start=10#208997
A-Axis moves fine when tested in PncConf
16 May 2021 00:45 #209015 by eighthaxis
OK I have got rid of the Joint Following Errors
I still need to figure out how to get the rotary index's A and B to be scaled correctly.
Time to create page: 0.132 seconds
