Please help me get this Homing Sequence Right
5 years 5 months ago - 5 years 5 months ago #208966 by Michael
Replied by Michael on topic Please help me get this Homing Sequence Right
I think we need to slow down a second. The best analogy for what your missing is that your wires (hal wording) are not connecting to the correct things. Look at this example:
# --- BOTH-X ---
net both-x <= hm2_5i25.0.7i77.0.0.input-00
This would work functionally the same as:
net i-like-turtles <= hm2_5i25.0.7i77.0.0.input-00
The words after net are just a naming convention and anything can be used for that particular "wire". The parts after the i-like-turtles is what wires connect to. Right now you just have a loose wire with one side connected.
A better way to right connections that visually make sense is:
net both-x hm2_5i25.0.7i77.0.0.input-00 =>
joint.0.home-sw-in
This says that the wire called both-x connects the 7i77 in 00 to the motion control pin for x axis home switch. The below says the same exact thing but written a different way:
net both-x joint.0.home-sw-in
Does this make sense? Your physical pins need to be connected to motion control of Linuxcnc.
linuxcnc.org/docs/2.8/html/man/man9/motion.9.html#JOINT%20PINS
You also have this:
net both-home-x <= hm2_5i25.0.7i77.0.0.input-00
which means you have two instances of loose wires for the same input
Last edit: 5 years 5 months ago by Michael.
5 years 5 months ago #208969 by tommylight
Replied by tommylight on topic Please help me get this Homing Sequence Right
eighthaxis wrote: I did what you said Tommy
net y-home-sw <= hm2_5i25.0.7i77.0.0.input-01
net both-y <= hm2_5i25.0.7i77.0.0.input-01
All that should be
net both-home-y <= hm2_5i25.0.7i77.0.0.input-01
This has to be done for all the joints/axis that use a single switch for home and both limits.
Check Michael's post to get an idea how things function.
5 years 5 months ago #208970 by Michael
So the above was just for a single x axis home switch. If you want the same pin to be used as a limit switch then you will need to connect the following:
joint.N.neg-lim-sw-in
and
joint.N.pos-lim-sw-in
Something like the following should make the same input function for negative limits, positive limits and homing switch also:
net both-x joint.0.neg-lim-sw-in
net both-x joint.0.pos-lim-sw-in
I am doing this from my phone and can't view some of the items I normally would but this should work.
The following user(s) said Thank You: eighthaxis
5 years 5 months ago #208981 by eighthaxis
Replied by eighthaxis on topic Please help me get this Homing Sequence Right
Thank you for the continual input. I will give it a try and get back to you.
5 years 5 months ago #209002 by eighthaxis
Hurray I have had some success thanks to your Help!
It will now Autohome XYZ successfully after adding your HAL entries and modifying the ini file a few times.
A and B are not homing correctly.
I keep getting joint following errors.
I can JOG B around with no joint following errors (although the scaling is wrong) but when homing it moves to the switch backs off about 25 degrees then give the joint following error
A-axis I can't jog at all because I can't figure out how to get the A jog buttons to appear in GMOCCAPY: forum.linuxcnc.org/gmoccapy/39723-edit-j...tons?start=10#208997
A-Axis moves fine when tested in PncConf
5 years 5 months ago #209015 by eighthaxis
OK I have got rid of the Joint Following Errors
I still need to figure out how to get the rotary index's A and B to be scaled correctly.
Time to create page: 0.264 seconds
