7i96 estop loop problem
- MarkD2
08 Jul 2021 17:36 #214039
by MarkD2
7i96 estop loop problem was created by MarkD2
This is my first time using the MESA 7i96 board. The estop button and screen controls seem to work ok but I am not getting a change on pin 14 with 24 volts on pin 13.
What did I do wrong?
MarkD
MarkD
- Thank you received: 5326
08 Jul 2021 18:07 #214042
Replied by PCW on topic 7i96 estop loop problem
If you have +24V on Pin 13 you have the output polarity of SSR0 backwards
OUT+ goes to the positive voltage source
The following user(s) said Thank You: MarkD2
- MarkD2
08 Jul 2021 19:46 #214045
by MarkD2
Replied by MarkD2 on topic 7i96 estop loop problem
I moved the wires but the output is active all the time. What did I miss?
08 Jul 2021 19:47 #214046
Is the LED for SSR0 on?
- MarkD2
08 Jul 2021 19:59 #214047
by MarkD2
yes
08 Jul 2021 20:12 #214048
I guess I would trace these signals
(the first token after net) with halshow,
starting with estop-out
net estop-loopout iocontrol.0.emc-enable-in <= estop-latch.0.ok-out
net estop-loopin <= iocontrol.0.user-enable-out => estop-latch.0.ok-in
net estop-reset iocontrol.0.user-request-enable => estop-latch.0.reset
net remote-estop estop-latch.0.fault-in <= hm2_7i96.0.gpio.010.in_not
net estop-out <= estop-latch.0.fault-out
- MarkD2
10 Jul 2021 18:54 #214208
by MarkD2
How can I invert ssr.00.out.00 as I need to have it active when out of estop.
10 Jul 2021 21:20 #214216
I would wire it to estop-latch.N.ok-out
- MarkD2
10 Jul 2021 22:47 #214222
by MarkD2
I changed net estop-out <= estop-latch.0.fault-out to estop-out <= estop-latch.0.ok-out and now I get an error that estop-latch.0.ok-out is already connected to estop-loopout
Can you send me to the appropriate place in the manual so I can understand how this works?
Thanks for your patients
10 Jul 2021 22:59 - 10 Jul 2021 23:06 #214223
Then instead change
net estop-out => [HMOT](CARD0).ssr.00.out-00
to
net estop-loopout => [HMOT](CARD0).ssr.00.out-00
There is the manual page for estop_latch, io and iov2 but there does
not seem to be a LinuxCNC guide to setting up Estop.
Skunkworks video is a nice introduction however:
forum.linuxcnc.org/24-hal-components/379...w-things-work-series
to
Last edit: 10 Jul 2021 23:06 by PCW.
Time to create page: 0.413 seconds
